Improving a subwoofer's sound
I have a Sony STR-DE595 receiver which I believe has a default setting of 120Hz (non-adjustable unless set large) on "small " with the line level hookup to the sub. Volume setting for sub on AVR -3. I have been advised to turn my KLH sub x/o all the way up. Volume at 9 oclock positon (quarter turn). Sound level meter calibrated at 80-81db with other speakers at 75db. Bass is a little boomy, especially when turned up for DD2 movie or music mode. I want to stuff it with polyfill, fiberglass or foam but dont know how or which one to use. Radio Shack had none but they said go to CC for special stuff. Can someone please tell me what to get and how to do it? I realize that this is not the best sub on the market and I want to try to tweak it as best as I can. Any thoughts on my settings would be appreciated too. Room size is 11"X10". Thanks.
Post edited by braveheart on
  • gatemplin
    gatemplin Posts: 1,595
    edited February 2004
    I had the same receiver and I remember it being at 120 Hz also. If you find the sub too boomy you can add polyfil. You can find it at walmart and it comes in a roll. It is used for making pillows or something. Just glue or staple the fill to the walls and keep it away from the port opening. You could also try plugging the port and see if that helps. Moving the sub Away from a corner usually helps also.
    Graham
  • braveheart
    braveheart Posts: 28
    Thank you for the advice.
  • braveheart
    edited March 2004
    Added polyfill and immediately noticed a punchier bass. Much clearer. Thanks for the tip again.
  • gatemplin
    edited March 2004
    No problem, glad you like the sub better now.:)
    Graham
