where can I get new metal jumpers from amp to pre-amp?
danger boy
i've read that by replacing the old metal jumpers that are on older receivers can help increase the sound on some older stereo gear. .... anyone know where I can get new ones? are there ones better than others?
PolkFest 2012, who's going>?
Post edited by danger boy on
They're shorting bars, you can get them from PE and not really.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
well. no luck on anything called shorting bar @ PE... ??PolkFest 2012, who's going>?
Is this what you're talking about: http://www.amazon.com/AudioQuest-Male-Male-Preamp-Jumpers/dp/B0006VMBGO?
They sound better than the old steel jumpers that came with my NAD integrated. -
On3s&Z3r0s wrote: »Is this what you're talking about: http://www.amazon.com/AudioQuest-Male-Male-Preamp-Jumpers/dp/B0006VMBGO?
yes.. that is what i'm looking for... I wonder if they come in pure silver wire???PolkFest 2012, who's going>?
You go get a nice peice of solid copper from the local hardware store, and cut and bend. I've done it I don't know how many times. You don't need the ground, just the copper. Cut it, bend it, stick it in. If you want it pretty, contact Frank Dai @ SC and have him make you a pair.
Cheers,
I have found that the distance from the pre-amp to main jacks are not a standard distance even among the same manufacturer. It is hit or miss finding the proper size pre-fab metal jumper. You are better with custom made jumpers or go with the short interconnects.
I am surprised no one suggested coat hangers yet.Stan
Main 2ch:
HT:
Other stuff:
If you're hung up on silver, you should be able to get some 14ga from a jewelry supply for about $20-$30 / foot.
For example:
http://www.fusionbeads.com/shop/product/31927/Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
i found the ones that go with my newly acquired Concept 11.0 in the bottom of the box.. so those will do for a week.. then i'll look for another better higher quality ones. I hear that a good jumper can make a difference.PolkFest 2012, who's going>?
Shorting pins like on XLR to Single Ended
Dedicated Audio has Cardas.
http://www.dedicatedaudio.com/inc/sdetail/1895/5158
Or do you mean actual rca to rca type straps?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Those are nice Brock, real nice.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
those are nice.. a bit pricey.. but nice..
Why are they there to begin with?
I’M OFFENDED!!!! -
Most of the time so you can put a equalizer in line with the reciever. So you go from reciever -> Equilizer -> Back to reciever. That or so you can use a external amp. My HK 3490 has them as well"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Audioquest has made them for years.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
EndersShadow wrote: »Most of the time so you can put a equalizer in line with the reciever. So you go from reciever -> Equilizer -> Back to reciever. That or so you can use a external amp. My HK 3490 has them as well
Thanks.never really needed to know.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
This is true. I have a hundred or so of "stock" NAD jumpers and they don't fit every RCA connection.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I have some of these and they fit what the generic ones did not.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Here they are...sorry, thought it was PE.
http://www.futurlec.com/RCA-Jumper.shtml
Here's a thread here with a couple clicks and slight hand movement.
http://www.polkaudio.com/forums/showthread.php?t=79177CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I'm going to bring this thread back to life as I just solved this issue for myself. I wanted to ditch the steel jumpers, so contacted the supplier of all my other cables, Luminous Audio, and they sent me out a DIY kit as a solution. Tim sent me four of his sliver, locking RCAs, and two short pairs of his silver reference wire. I soldered the connections myself last night, made the plugs, and their great! Highly recommended!
What's the cost on that Zingo? I'd be interested in a pair for the goody box.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I've been chatting with Tim from Luminous, and he is considering offering RCA jumpers that match each of his RCA cables with corresponding terminations and wire. With nothing officially on the table yet, he will send you out the same "DIY jumper kit" I bought from him with the silver, locking RCAs and reference, solid silver wire for $100 a pair. It's a solid package as the silver jumpers removed some fog from my system, and added just enough sparkle that works well with my copper speaker cables. PM me and I'll send you his email address, or he can be reached through the website.
Tim just sent me the pricing on the new RCA jumpers that will be a match to his current ICs; the DIY silver jumper set continues to be an option. This is a very nice option not only for reference quality jumpers, but they will also exactly match you current Luminous Audio ICs. They are not on the website yet, but should be if Tim is a smart guy. :biggrin:
Monarch $60
Renaissance $80
Signature $100
Synchestra $120
Synchestra Signature $140
Synchestra Reference $180
Silver Reference $200
