Settings for RtiA7
I'm looking at buying a Polk Rtia7. My question is since i have a sub what cross over setting sould i set the front speaker at? I'v read post that say set the cross over at 80, send all low frequency to the sub.
Or should i set at full range .I've also read that a Rtia5 with a sub is better then rtia7 without. Since i have a desent sub (dsw micropro 2000) the latter is not a option. So i`m wondering on the recommendation on the settings.
Thanks in advance.
Thanks in advance.
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
Vizio P65-C1
Universal Remote
Post edited by over50 on
I would set the crossover at 80 and set fronts to large."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I'm pretty sure if they are set to large it does not matter what the crossover is set at as it will run them full range.
I would cross them at 80 to start and set to small. If you think they can handle a bit more, bump them down to 60.
I ran mine at 80 most of the time.
Good luck with your new speakers. -
Come to think of it gfong is right, set front to small."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
I have mine set to large and crossed over at 60.
Your AVR will determine some of these parameters since some won't let you choose one without a default to another. They can certainly run full range but I'd start with small @ 80hz.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I currently have my 7s set to full range and the double bass on. That way you will still have output from the sub.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Here's a great article on the subject matter. My entire LSi 5.2 system is set to "small" & the 80Hz XO is used for all speakers. Sound awesome for both HT & 2 channel. I've played around with various set up's & settings but the "small"/80Hz XO always provided the best audible results.
http://forum.ecoustics.com/bbs/messages/34579/128214.html"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
That is a good article.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I have my RTi10's ( basically the same as the 7's ) set to small with my crossover I believe set to 80 Hz.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
it depends on your ears. I've rti8s, which is same as the Rtia5, but set at small 70hz because at 80hz, I still hear voices, directional coming out of the sub.
