Review of Cable X
Hawkeye
Hawkeye Posts: 1,313
edited May 2011 in 2 Channel Audio
About three weeks ago, Gary (TNRabbit) stopped by the house to drop a piece off and listen to my system a bit. He gave me a set of speaker wires to listen to. I have no idea how much they cost nor where they came from. He did mention they are a homebrew by a guy from a site. During this review, I?ll refer to them as Cable X and let Gary or the builder (if he is a member here)divulge the cost if they see fit.
I?ve had the WireWorld Eclipse 6.0 installed in my system for about two years and know them well. I bought these cables new for $1400.00. I only mention the price for a comparison. Cable X was installed on the 4 Ohm tap as were my WW?s. Nothing else was changed. For reference, I listen to a lot of jazz and female vocalists. Holly Cole, Patricia Barber, FourPlay, Ritenour, Spyro Gyro and early 60?s jazz.
My first impression is the lows are very accurate. An upright bass had the weight and tone I expect. Kick drums had the impact and decay which was/is more accurate than the WW?s. As a matter of fact, as an experiment, I turned off my subs and found just the speakers alone provided more than adequate bass. I?ll admit it, with these wires I probably don?t need the subs.
The mids and highs are a bit warm, perhaps a bit much when combined with my gear. My gear is a bit laid back in my opinion and with these wires I have too much of a good thing. I didn?t find it unpleasant in the least and after awhile, it did start to grow on me. Horns are a bit softer but missing the bite I expect. Same result with higher piano notes. Had I thought of it, I could have removed some of the room treatments to liven the room and it may have been a bit crisper. For the most part and depending on the music, Cable X was a very enjoyable piece.
Imaging and stage was absolutely superb!! There was depth and height I do not receive with the WW?s. Instruments were where they should be and easily locatable.
There was one thing that would make me hesitate keeping these wires. I experienced moderate amounts of sibilance which I have never had in my system before.
Overall I found Cable X to be a very solid performer and in a couple areas, give it the edge over my WW?s. I think if the sibilance did not show itself, I could and would consider using it. I suspect that a less revealing system (non-ESL) would benefit from these wires. I?d have liked to try the SDA?s with these but the logistics of moving them from the shop was beyond me for now. I strongly recommend if you get a chance to audition these, you do so. They are quite impressive.
Gordon
2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
Post edited by Hawkeye on
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2011
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • megasat16
    megasat16 Posts: 3,521
    edited May 2011
    Nice Review, Gordon.
    Gary, your links hurt me in some ways I can't explain. :biggrin:
    I guess the difference is subtle but it's there if your rig is up to it and you are doing critical listening. But the price not so subtle.
    A good wake up call, fellas.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • slammin86
    slammin86 Posts: 238
    edited May 2011
    Thank you for the time to do this. When I sold them I had no idea someone was going to do a review on them.
    I have the same wires in my system and love them, but I have not had the opportunity to compare them to anything nice. Glad to see they can hold their own.
    Receiver: ONKYO 709
    Amplifier: Acurus A200x3
    Front: EmpTek E55Ti
    Center: EmpTek E56Ci
    Surround: EmpTek E5Bi
    Sub: Elemental Designs A5-350
    TV: LG 55"
    Blu-Ray: PS3
    heiney9 Posts: 25,510
    edited May 2011
    Canare Star Quad is very hard to beat for the price. I use it in the office rig and it sounds very good. Won't dethrone my MIT's anytime soon, but for an inexpensive DIY project they sound great.
  • Hawkeye
    edited May 2011
    slammin86 wrote: »
    Your welcome and it was my pleasure indeed!! I hope you don't mind I did a review without your permission. I didn't know who's they were to ask.
    As Mega mentioned, subtle differences, not so subtle a price difference. And as H9 said, they won't dethrone the WW's, but they are a fine, all around solid piece!!
    Gordon
    2 Channel -
  • slammin86
    edited May 2011
    Hawkeye wrote: »
    Gordon
    I'm glad you did.
    Maybe I should make a few more pairs of these to sell.
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • Hawkeye
    edited May 2011
    slammin86 wrote: »
    I'm glad you did.
    Build me a set and I'll buy them!! I'd prefer large spades on the speaker end.
    Gordon
    2 Channel -
  • slammin86
    edited May 2011
    Hawkeye wrote: »
    Gordon
    If I did more I would want to buy enough cable and everything to help absorb shipping cost and bring the cost down. If there is enough interest I will make a big purchase.
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • TNRabbit
    edited May 2011
    slammin86 wrote: »
    Update?
    TNRabbit
    Sunfire TG-IV
  • Rodeo0530
    Rodeo0530 Posts: 797
    edited May 2011
    I might be very interested in this depending on the cost in the end, but it doesn't sound like it would be too bad of a price.
    Front - Polk Audio Monitor 70
    Center - Polk Audio CS2
    Rear - Polk Audio TSi 100
    Sub - Klipsch rw-10d
    AVR - Onkyo ht-rc180
    Main Amp- Parasound HCA-2003
    Surround Amp- Sonance Sonamp 260
    Tuner- Parasound tdq-1600
    Turntable- Pro-ject Debut III USB w/upgraded platter
    IPod dock - Pure i20
    TV - Panasonic Viera tc-p46g10
    Sony Playstation 3(250GB)
    Nintendo Wii
    Power Conditioner- Panamax 5100
    Not in use-
    Polk Audio Monitor 60
    Polk Audio PSW10
    Parasound p/sp-1000
  • slammin86
    edited May 2011
    TNRabbit wrote: »
    Update?
    Rodeo0530 wrote: »
    I will come up with a cost based on 5 people buying a 9 ft pair tomorrow. If there is interest I will order the stuff and start making them.
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • Systems
    Systems Posts: 14,872
    edited May 2011
    slammin86 wrote: »
    Swatimtalkinabout!:wink:
    Testing
    Testing
    Testing
  • Hawkeye
    edited May 2011
    slammin86 wrote: »
    Would you consider changing one end of the cable to spades? I'd be willing to come up with the difference if required. Or perhaps a bi-wired configuration with 4 large spades on the speaker end? The bananas on my speaker side are frankly a bit short. Not a reflection on your build, but MArtin Logan has a funky connector on the speaker which somewhat demands a spade. Let me know. I've got the cash and Gary's wires which I'm hesitant to give back:biggrin: Don't worry Gary, I'll part with them soon!!!!
    Gordon
    2 Channel -
  • Systems
    edited May 2011
    I have been trying to talk Shane into making more of these sets for a while now.
    Polking (pun:biggrin:) and prodding (with an electric prod twice!:eek:).
    I bet it would not take much convincing to talk me into a pair:wink:
    Power cable/s swap?:tongue:
    Testing
    Testing
    Testing
  • slammin86
    edited May 2011
    Hawkeye wrote: »
    Gordon
    I can do whatever you want. Here is what is on mine.
    pepster wrote: »
    LOL that is true.
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • slammin86
    edited May 2011
    Ok here is what I came up with. I would need an order of 5 pairs to make this price work.
    We have a few different options on banana plugs. I want to stick with the GLS plugs as they are a proven high quality plug. The different types can be seen here.
    http://www.speakerrepair.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=AHH_Banana
    I have used the carbon and black techflex and like the color of both. I will plan to make them all carbon but could do special requests.
    1 pair of 8 ft cables = $125 shipped
    1 pair of 8 ft cables bi wire one end = $145 shipped
    1 pair of 8 ft cables bi wire both ends = $165 shipped
    I can do special lengths, center cables, basically whatever.
    If anyone is interested please let me know. If I could get 5 people to commit I will pull the plug and order materials. I would like for everyone to put down a $50 dollar deposit through paypal. I will not take a deposit from anyone until 5 people have committed.
    Any feedback?
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • Hawkeye
    edited May 2011
    If you would consider special requests on the techflex, where do you order it from? I'd like to see the colors available and give you the color.
    I'm down for a 8 foot pair with bananas on one end and four spades on the other.
    Gordon
    P.S. I hope you figured in a profit for yourself. You deserve it!! By the way, what is your real name if your willing to to post it?
    2 Channel -
  • slammin86
    edited May 2011
    Hawkeye wrote: »
    Gordon
    http://www.wirecare.com/products.asp?prodline=PTN
    If you select the color from the pull down menu it will change the picture. Then you can enlarge it.
    My name is Shane
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
  • slammin86
    edited May 2011
    Receiver: ONKYO 709
    Front: EmpTek E55Ti
    TV: LG 55"
    Blu-Ray: PS3
