question about my speakers?
S T R Y K K E R
S T R Y K K E R Posts: 77
edited May 2011 in Speakers
I have an Onkyo 1008 9.2 receiver
with the following speakers.
Fronts ---R50's
Center ---CS20
Height & Width ---R150's
Left/Right ---R150's
Back Surrounds ---R150's
Subwoofers --- 2 BIC F12's
All my speakers have 3/4 tweeters---(EXCEPT for the CS20)
Im thinking of purchasing the Monitor 70's that way my Fronts and Center will have same tweeter..........
Will it make that big of a difference in sound if I replace the R50's with the 70's???
If I do decide to buy the 70's..............then my Height,Width and surrounds will still have 3/4 tweeters..Will it sound weird/mismatched? :confused:
16' x 12' Man Cave :smile:
Onkyo TX-NR1008 9.2 AVR
Polk Monitor 70's--Mains
Polk Monitor CS2--Center
Polk Monitor 30's--L/R Height's & L/R Wide's
Polk Monitor 30's--L/R Side Surround
Polk Monitor 30's--L/R Back Surround
(3)BIC Formula-12--Sub's
(4)Aura Pro Bass Shakers with Crown XLS 1000 amp
Emotiva-XPA-3 AMP for L/C/R
Epson 8100--1080p LCD projector
120" Elite Screen-- High Contrast Gray
Sony BDP-CX960--400 disc BLURAY player
Sony DVP-CX995--400 disc DVD player
XBOX 360 & PS3
Post edited by S T R Y K K E R on
  • Geoff4rfc
    Geoff4rfc Posts: 2,851
    edited April 2011
    Nice looking equipment. Yeah, I'd think you'd notice a pretty decent upgrade with the 70's over the 50's.
    It's your front stage that matters the most (L, C, R) as far as matching goes. The CS20 "naturally" goes with the TSi line and the CS2 "naturally" goes with the Monitor line, but you can still mix and match the TSi's with the Monitors without noticing a huge difference, I mean, you'd really need a trained ear to make the call.
    As far as the other question, your surrounds will do just fine with the rest of the set up but consider this, a 7.2 will strain your system alone, a 9.2 will stress it even more, you might consider a multi channel amp with at least 3 channels if not 5.
    I run an 807, I think it has the same power as your 1008. I ended up putting a 3 channel amp in the mix and the 7.2 I run handles the sound very comfortably. For you to run a 9.2, I'd think you'd do very well with some extra power.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • S T R Y K K E R
    edited April 2011
    Thanks alot for the informative reply Geoff4rfc.......
    I'm going to buy a set of M70's......can't wait to see what my setup sounds like once its complete.....was a little worried about the mixed tweeters not sounding right.
    A good amp is my next purchase,hopefully in a couple months.
    XBOX 360 & PS3
  • Geoff4rfc
    edited April 2011
    Thanks alot for the informative reply.
    Your welcome, and you will totally dig the new sound!! I had a pair of 30's and a CS2. When I added my 70's to the set up, I felt like I had a really nice system.
    The 70's will sound better over time as they break in. Be careful not to feed too much volume into your speakers especially if you're going to use all 7 or 9 speakers at once, not having enough power to drive all speakers at once can cause some damage to them. But once you have your amp, let 'em rock.
    Congrats again on your new purchase.
    Set up:
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    Enjoy, love my 70,s now doing surround duty and doing it well, great speaker.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • S T R Y K K E R
    edited May 2011
    Is the XPA-3 a good amp?
    How would I run it?
    Do I come out of the pre-outs l/r/c from onkyo 1008 and into the amp with an rca cable for each l/r/c?...and then run wire from amp to speakers......
    Is it that simple?
    Will I still be able to get Dolby TrueHD lossless & DTS Master lossless....since the fronts & center are coming out of the preouts and the rest are direct connected to 1008?
    XBOX 360 & PS3
  • Cmiller
    Cmiller Posts: 108
    edited May 2011
    Yes,its that simple...and yes also, you will still be getting TrueHD and DTS lossless sound if your running a sperate amp,all your doing is adding more power with adding the amp,and using your 1008 as a pre amp..
    Samsung PN50B550 Plasma
    Pioneer Elite SC-25
    Pioneer Elite BDP-23FD
    Adcom 7500 Amp-Panamax 4300 Conditioner
    Polk RTi10's Fronts
    Polk Csi A6 Center-Polk M60s rear Surrounds
    Klipsch Synergy Sub-10 X2
    Klipsch Synergy S-10 Premium back surround
  • Geoff4rfc
    edited May 2011
    Cmiller wrote: »
    Yes, I second that!!!
    Strykker, I have the 807 with 70's and a CS2 hooked up to my XPA-3. The Onkyo only has to feed power to my surrounds.
    HD-Master Audio and works, it's all there. You lose nothing by adding the amp and gain extra power to drive your system.
    Three RCA cables out from pre-outs on the back of the receiver and into the amp, switch to unbalanced on the amp, run speaker wire from amp to speakers and presto, instant combustion.
    Set up:
  • S T R Y K K E R
    edited May 2011
    NICE.......now all I need is $700.00.....Im taking donations anybody want to give???
    I should be able to order the XPA-3 in about a month...heck I just finished ordering my last Monitor 70 yesterday from J&R audio..I ordered 1 at a time....MAN THIS IS GETTING EXPENSIVE..I LOVE ELECTRONICS though...LOL
    Will a good heavy duty rca cable work for the AMP?I have some rca cables I ordered from Monoprice that are like ropes their very thick(never use them now though,HDMI took over).
    XBOX 360 & PS3
  • Hawkeye
    Hawkeye Posts: 1,313
    edited May 2011
    From my research and just plain reading, EMO amps are/can be very sensitive to the quality of the RCA used. There have been many instances of channels failing due to a "faulty" rca cable. Not that you have to spend mega dollars, but you need to have some spares laying around in the event a channel goes red to keep the system up.
    I find this hard to believe. I've been into audio since 1978 and have never had a component die because of a a faulty RCA. But, do your due research on an EMO piece and you'll want some spare RCA's on hand.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • S T R Y K K E R
    edited May 2011
    Thanks Hawkeye for the info,Im not deadset on an XPA-3....are their any 3 channel amps out there for around the same price or cheaper as the EMO that will give me 200 watts per channel?
    XBOX 360 & PS3
  • Hawkeye
    edited May 2011
    I"m not trying to sway you against the EMO piece. Just be aware of the RCA issue. I thought the EMO amp was a good addition to a HT setup. I don't know of any other company which would match their level and price. I'm certain some other folks will chime in with a good, alternate choice for a three channel amp.
    Gordon
    2 Channel -
  • slk55amg
    slk55amg Posts: 305
    edited May 2011
    I have an EMOTIVA XPA5 , runs cool, rock solid, plenty of power, drives the five speakers in my signature with ease. I am using emo "ultra interconnects" never a problem, nice interconnects, superior build quality.
  • Hawkeye
    edited May 2011
    slk, I'm glad you jumped into this. I thought the XPA-5 was nice piece for a HT setup. Not so impressed on the 2 channel side. But it is a fair piece. I thought it fair to mention the sensitivity of the EMO pieces to substandard RCA's. I have no axe to grind with EMO so I'm neutral on all the fluff that goes on.
    I hope the OP has an open mind and can accept both positive and negative comments on his potential choice of amps.
    Gordon
    2 Channel -
  • Geoff4rfc
    edited May 2011
    I've had my XPA-3 for close to a month now and have it hooked up with the X-series cables. Haven't had any troubles with either 2 channel or HT 7.1.
    After some research, I found better equipment out there but none could match this price per wattage. Being on a budget sucks but fortunately, there's something out there for the budget minded like myself.
    Set up:
