Can You Identify This Power Cord???
mufsoman
mufsoman Posts: 636
edited May 2011 in Electronics
This power cord came with my Rotel amp which I purchased second hand. I assume its not the stock cable that originaly came with the amp (?). The RF filter and cable jacket say "Audioquest" The 3 prong connector says "Hubble". The IEC connector is Schurter.
I looked on the Audioquest website and this doesn't match any stock cords listed, although it could be an older model.
Does anyone recognize this cord? Is it a stock Audioquest cord? Is it a DIY cord? If a stock Audioquest cord, what quality level is it? Is it worth an upgrade from this or is it high quality? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
  • mufsoman
    mufsoman Posts: 636
    edited May 2011
    How about some pics....
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • Systems
    Systems Posts: 14,873
    edited May 2011
    Looks like an older AC 15.
    Do you like it?
    That is a Schurter IEC with Hubbell male on yours.
    Here is a pic I found on the net, Hubbell male with Wattgate IEC:
    Testing
    Testing
    Testing
  • mufsoman
    mufsoman Posts: 636
    edited May 2011
    Pepster - I just installed your power cords last night, so I still some testing to do over the weekend. I took a closer look at the amp cord after I replaced with your 4'.
    Where does an AC-15 fall in the food chain? Is it considered bargain or higher quality?
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • Systems
    edited May 2011
    mufsoman wrote: »
    I think it is considered a bargain cable.
    I was wondering if you liked the Audioquest?
    Testing
    Testing
    Testing
  • cristo
    cristo Posts: 231
    edited May 2011
    I know. It's a 120 Volt 60 Hz power cable!
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • inspiredsports
    inspiredsports Posts: 5,502
    edited May 2011
    I see it's clearly marked Audioquest, but the color scheme looks like older Groenberg stuff, http://www.groneberg.com/english/quattro/quattro.html . . . they no longer use orange
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
