Advice on my system.
Systems
I'm not to good with the systems, but I got an 89' mustang with 4 12' JL audios that are in the backseat. I have a few friends who have just 1 or 2 12's and it hits harder. I have a 2500 watt amp. pushen it, but im thinken it could be because i have no ports on the box. Have any suggestions?
Testing
Testing
Testing
Testing
Testing
Originally posted by Chase
4 12' JL audios that are in the backseat. ..... just 1 or 2 12's and it hits harder. ..... no ports on the box.
What you mean in the back seat??
And i wouldn/t port JL's i have heard them operate better in sealed enclosures.. I wouldnt use jl's but a few friends o0f mine did for a while.. then got kappas... changing the sub made a hell of a difference...___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
what is the 2500w amp? what do you mean by back seat? You cant just port a sealed box btw....
little more details can get you some more direct help
good luck -
i think this one drilled a port into the back of his cranium and all his "brainz" drained out over time... or if his brain tissue was of the same resonant frequency as the port's tuning frequency, this could have resulted in the same symptoms.
- Dr. Vinnie.The Artist formerly known as PoweredByDodge -
I concurOriginally posted by PoweredByDodge
- Dr. Vinnie.
-Dr. Cody -
Dr. Cody, do you think we need to send 'em to a specialist ?The Artist formerly known as PoweredByDodge
Polk, the speaker specialists?
I think we should send em to JL, or bose...
-Dr. Cody -
I heard Road Gear was looking for people to sponsor!!:eek:
Face it, everyone is a genious/ expert/ guru when it comes to posting on the internet. It is easy to weed out the imposters however.
The poster asked a question because he wanted some feedback. Personally I think it makes sense to ask about something when you are unsure, however it makes no sense at all to post like a little giggley girl and attempt to ridicule someone else for asking a question, no knowledgable poster would stoop to that level. Car audio is not an instinct, everyone had to learn what they know from others, whether in print, practice, or whatever. The ones who know the least are ALWAYS the most obnoxious and first to slam others. Look in any car owned by a smart-azz reply poster, you will find either:
1) No System, If you find a system at all, it will not be what they claim it is, in fact it will likely be a butchered factory mess with a quadzillion watt label swapmeet amp somewhere in the tangle making loud distortion through unmounted speaks with dad's old 3 way spitting confetti buzz as the sub.
or
2) The latest & greatest of everything, thanks to mom's credit card or someone with a slim-jim. Sounds worse than a garbage truck on a bumpy road and three times louder to drown the noise of the butchered exhaust system combined with the alternator's overworked neon whine & the rattles from poor ride due to the low profile wrong offset rims & tires
Or a combination of the two.Testing
Testing
Testing -
or
Club Polk Forum, I'd like you to meet Angry Man.
Angry Man, Club Polk Forum.
Now y'all play nicey nice, ok?Expert Moron Extraordinaire
2 months and 6 days later..."survey says" decided to chime in...nice...
-Cody -
-Cody
1 hour & 28 minutes later survey says you're late...
LOL the vultures r hovering....Originally posted by Jstas
Pleasure to meet you Polk forum.
Angry? Not a bit well, maybe at the guy in the van who sold me the speakers...
SS Happy listening.
~Survey Says~
~1982 Reliant~
~Gremlin bucket seats~
~Factory AM with beercap volume knob~
~Kraco Topsound 5 band equalizer/power-booster~
~Under dash Spark-o-matic FM converter~
~Wire nut Y split zipcord for simulated stereo FX~
~Dual Realistic antenna boosters~
~Removable Custom Bent Hanger wire antenna~
~Heavy Duty Foil wrapped fuse~
~Assorted speakers & bracketry~
**Best in trailer park** '84 '85 '90 '99Testing
Testing
Testing -
i slept with two girls from trailerparks -- both good in bed -- bad in brains.The Artist formerly known as PoweredByDodge
See if you recognize them here:
http://www.mytrailerpark.com
SS Happy listening!Testing
Testing
Testing -
Original Poister - No offense, but your install must suck. What kind of JLs do you have? You must know what kind of sub you have. What sub did the other guy have? My 1 12" beats 4 12" sony eXplodes so it does make sense that you could lose, but depending on your JLs, you maybe should have won.Testing
Testing
Testing
