Advice on my system.
Systems
Systems Posts: 14,872
edited February 2004 in Car Subwoofer Talk
I'm not to good with the systems, but I got an 89' mustang with 4 12' JL audios that are in the backseat. I have a few friends who have just 1 or 2 12's and it hits harder. I have a 2500 watt amp. pushen it, but im thinken it could be because i have no ports on the box. Have any suggestions?
Testing
Testing
Testing
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited January 2004
    Originally posted by Chase
    4 12' JL audios that are in the backseat. ..... just 1 or 2 12's and it hits harder. ..... no ports on the box.
    What you mean in the back seat??
    And i wouldn/t port JL's i have heard them operate better in sealed enclosures.. I wouldnt use jl's but a few friends o0f mine did for a while.. then got kappas... changing the sub made a hell of a difference...
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited January 2004
    what is the 2500w amp? what do you mean by back seat? You cant just port a sealed box btw....
    little more details can get you some more direct help
    good luck
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2004
    i think this one drilled a port into the back of his cranium and all his "brainz" drained out over time... or if his brain tissue was of the same resonant frequency as the port's tuning frequency, this could have resulted in the same symptoms.
    - Dr. Vinnie.
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited January 2004
    - Dr. Vinnie.
    I concur
    -Dr. Cody
  • PoweredByDodge
    edited January 2004
    Dr. Cody, do you think we need to send 'em to a specialist ?
  • sntnsupermen131
    edited January 2004
    Polk, the speaker specialists?
    I think we should send em to JL, or bose...
    -Dr. Cody
  • TrappedUnder Ice
    edited January 2004
    I heard Road Gear was looking for people to sponsor!!:eek:
  • Systems
    Face it, everyone is a genious/ expert/ guru when it comes to posting on the internet. It is easy to weed out the imposters however.
    The poster asked a question because he wanted some feedback. Personally I think it makes sense to ask about something when you are unsure, however it makes no sense at all to post like a little giggley girl and attempt to ridicule someone else for asking a question, no knowledgable poster would stoop to that level. Car audio is not an instinct, everyone had to learn what they know from others, whether in print, practice, or whatever. The ones who know the least are ALWAYS the most obnoxious and first to slam others. Look in any car owned by a smart-azz reply poster, you will find either:
    1) No System, If you find a system at all, it will not be what they claim it is, in fact it will likely be a butchered factory mess with a quadzillion watt label swapmeet amp somewhere in the tangle making loud distortion through unmounted speaks with dad's old 3 way spitting confetti buzz as the sub.
    or
    2) The latest & greatest of everything, thanks to mom's credit card or someone with a slim-jim. Sounds worse than a garbage truck on a bumpy road and three times louder to drown the noise of the butchered exhaust system combined with the alternator's overworked neon whine & the rattles from poor ride due to the low profile wrong offset rims & tires
    Or a combination of the two.
    Testing
    Testing
    Testing
  • Jstas
    Jstas Posts: 14,999
    or
    Club Polk Forum, I'd like you to meet Angry Man.
    Angry Man, Club Polk Forum.
    Now y'all play nicey nice, ok?
    Expert Moron Extraordinaire
  • sntnsupermen131
    2 months and 6 days later..."survey says" decided to chime in...nice...
    -Cody
  • Systems
    -Cody
    1 hour & 28 minutes later survey says you're late...
    LOL the vultures r hovering....
    Pleasure to meet you Polk forum.
    Angry? Not a bit well, maybe at the guy in the van who sold me the speakers...
    SS Happy listening.
    ~Survey Says~
    ~1982 Reliant~
    ~Gremlin bucket seats~
    ~Factory AM with beercap volume knob~
    ~Kraco Topsound 5 band equalizer/power-booster~
    ~Under dash Spark-o-matic FM converter~
    ~Wire nut Y split zipcord for simulated stereo FX~
    ~Dual Realistic antenna boosters~
    ~Removable Custom Bent Hanger wire antenna~
    ~Heavy Duty Foil wrapped fuse~
    ~Assorted speakers & bracketry~
    **Best in trailer park** '84 '85 '90 '99
    Testing
    Testing
    Testing
  • PoweredByDodge
    i slept with two girls from trailerparks -- both good in bed -- bad in brains.
  • Systems
    See if you recognize them here:
    http://www.mytrailerpark.com
    SS Happy listening!
    Testing
    Testing
    Testing
  • Systems
    Original Poister - No offense, but your install must suck. What kind of JLs do you have? You must know what kind of sub you have. What sub did the other guy have? My 1 12" beats 4 12" sony eXplodes so it does make sense that you could lose, but depending on your JLs, you maybe should have won.
    Testing
    Testing
    Testing
