which sub is better
dekuleaf
dekuleaf Posts: 26
what will hit harder two psw110 or one psw125
Post edited by dekuleaf on
  • B Run
    B Run Posts: 1,888
    edited May 2011
    I'd go with a Psw505 if you can find it, the psw110 doesn't dig low or get that loud, so running 2 of them will still leave you wanting more. I'd always go quality over quantity.
  • dekuleaf
    dekuleaf Posts: 26
    edited May 2011
    are there any subwoofer in current production right now youd suggest with in a 400 dollar price range
  • slk55amg
    slk55amg Posts: 305
    edited May 2011
    there is a polk micropro 2000 listed on polk,s ebay site for $499.95
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • BWilberg266
    BWilberg266 Posts: 191
    edited May 2011
    My best suggestion to you would be to sit back, relax, and spend a good month or so reading and researching about audio gear before you start spending your money.
    I just took a quick look at your list of threads you have started recently
    -what are recievers
    -what is a sound bar?
    -which sub is better
    -what subwoofer is the best match
    I think it's best if you do a little research for yourself to actually know what it is your buying, and why your buying it before you start spending your money. Look into the sound characteristics of the speakers and equipment your looking at, read reviews for yourself, decide what is most important to you.
    I know we have all gone out and bought something only to turn around and sell it right away because we found something better or it wasn't what we thought it was going to be. Take your time, once your sure of what it is you want, you will be much happier once you have it in your setup.
    Main Setup
    Fronts - Energy RC-50's
    Center - Energy RC-LCR
    Rear - Energy RC-R's
    Subs - Gone...
    AVR - Pioneer SC-37
    Blu-Ray - Sony BDP-S360
    TV - Vizio E550I-B2
    Media Server - Mac Mini
  • catib999
    catib999 Posts: 5
    edited May 2011
  • robsreef
    robsreef Posts: 33
    edited May 2011
    I've been very pleased with this purchase. It was an upgrade from a decade-old PSW-120:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-770
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited May 2011
    -what are recievers
    Nice post - great advice! :smile:
  • BWilberg266
    edited May 2011
    Deku,
    Any news on what you've been finding about what you're looking for/what you're learning?
    We're here to help so keep the questions coming, it's the best way to learn!
    Main Setup
    Subs - Gone...
    AVR - Pioneer SC-37
    TV - Vizio E550I-B2
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    dekuleaf wrote: »
    Out of the two you asked about specifically, the PSW125.
