DAC/Preamp
audiocr381ve
audiocr381ve Posts: 2,588
edited May 2011 in 2 Channel Audio
Hey guys, I'm looking for a DAC/Preamp combo unit and just more information in general about buying these "combo" units. Are separates the way to go for preamps and DAC's?
Seems so much more convenient to combine the two. I've spent a lot of time over at the Audio-gd website. They don't offer a combo unit but seem to be held in high regard. Any thoughts on them?
Budget is $500. Can't push that, unless I want to be a newspaper headline because my wife would kill me.
Post edited by audiocr381ve on
  • punk-roc
    punk-roc Posts: 1,150
    edited May 2011
    I enjoy the simplicity of my Peachtree Nova Pre/Dac and W4S Dac-2 Pre/DAC.. it all depends on the implementation.. some combo's are great, others less so..
    Neither of those options are in the $500 range unfortunately.. I'm sure others will chime in with some decent options in that range..
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • headrott
    headrott Posts: 5,496
    edited May 2011
    If you are relatively good at soldering and power supply/board layout I would recommend the Buffalo II with the Volumite option from Twisted Pear as a DAC/Pre combo. The analog stages they have are only SS, but if you are happy with that then it should be relatively simple to do, and with a case, etc. within your budget (barely). I just finished one with tube output and it sounds phenominal. Just think about it as an option, unless you find something you prefer more. Twisted Pear is found here:
    http://www.twistedpearaudio.com/landing.aspx
    Greg
  • audiocr381ve
    edited May 2011
    headrott wrote: »
    Greg
    Hmmm...that's very interesting. I've done some very light modding and I think my soldering skills could be up to the task. Could you give me a little more information on this?
  • headrott
    edited May 2011
    What are you looking to find out about it?
    Greg
    Edit: Oh, and the Buffalo II DACs are on sale right now! I would seriously consider getting one with the placid.
  • audiocr381ve
    edited May 2011
    Not knowing how to tell if one spec is better than another myself, how does the Buffalo II compare with the Audio GD NF3?
    http://audio-gd.com/Pro/dac/NFB-2/NFB2EN.htm
    Also, it looks like all I'm getting is a module. Does that mean no housing? Switches etc?
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    The Peachtree Decco sounded pretty damn good, and is somewhat mod friendly. Stock unit's are available for about $450 used.
    Step up to the Nova as Greg suggested and you'll get the ESS Sabre DACs (and plenty more), though for a couple hundred more (but totally worth it).
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • [Deleted User]
    [Deleted User] Posts: 1,223
    edited May 2011
    A DAC I was strongly considering was the Audio Fidelity V-DAC ($299). From all I read it was even better with the upgraded power supply. User's tried it with a Pyramid regulated supply and a fancier Kingrex unit that was more expensive. I was able to find an AMC DAC 8 for less than $100 that I am currently using. The DAC 8 is an older unit but is very musical. I have to concur with others that posted about this dac, that it was hard to beat for the money. Cheers. :cool:
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2011
    I have a Benchmark DAC1 which I'm VERY happy with; you MIGHT be able to find a used one for $500....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • sucks2beme
    sucks2beme Posts: 5,691
    edited May 2011
    TNRabbit wrote: »
    A fine choice of a DAC. But $500? They go for a lot more than that used.
  • headrott
    edited May 2011
    The Sabre DAC (contained on the Buffalo II) has some of the best specs on the market currently. The Buffalo II (Sabre ESS 9018) has better (overall) specs than the WM8741. Plus, there are only 2 WM8741 chips used in the NFB-3 (opposed to 4 ESS ES9018 chips used in the Buffalo II module) resulting better sound (clarity, imaging, separation, etc.).
    You are correct in that the Buffalo II is only a module. You would have to buy the Placid power supply and a transformer to power it as well. Also, it would not come with a chassis or power switch either. The Buffalo II would be a DIY project and would require you to source the parts and assemble it. The positive side of that would be you could customize how the DAC/Pre is put together, plus you would potentially get a better DAC/Pre for less money.
    Something to think about anyway.
    Greg
  • steveinaz
    steveinaz Posts: 19,546
    edited May 2011
    How many inputs do you need? Will you need an analog input?
    You might squeeze a used Benchmark DAC1 (basic version/non-usb) for $500.
    I've been using a Benchmark as my pre/dac for over 6 years.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2011
    steveinaz wrote: »
    A regular DAC1 or the DAC1/Pre model? I have both and did use the DAC1/Pre as a pre-amp for a while, but I got tired of getting up and down to adjust the volume. :biggrin:
  • steveinaz
    edited May 2011
    Both. The first 5years was the non-usb base Benchmark DAC1.
    I did too...that's why I use it line-level now, into my Placette remote control passive. hehe.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited May 2011
    steveinaz wrote: »
    I got tired of getting my fat **** off the couch to turn the tube amp volume up but then I got a squeezebox and now I just use the volume on that via the remote
  • steveinaz
    edited May 2011
    I think you may be compromising fidelity using the volume control on that squeezebox. I believe the conventional wisdom is to leave that set a max output.
    Maybe Brock can confirm...
  • audiocr381ve
    edited May 2011
    Hey ya'llz, I thought I'd close this out and let you guys know what I ended up deciding on.
    Emotiva XDA-1 is on it's way! The response to this DAC has been awesome for the most part. What really sold me besides all the happy owners reporting a huge improvement, is its functionality. It comes with a remote and balanced outputs (for future upgrades ;).
    I'm thrilled :)
