first timer here, need some simple questions answered please
jonnyBoy101
1. I'm planing on rewireing my whole car, i want to knew what wires to get or what is recommend to for polk speakers?
2. I was thinking of getting a bass control knob and i wanted to knew which one to use, which is the best to use. i have a Carbon series C300.2
please help,
thanks
please help,
thanks
Post edited by jonnyBoy101 on
If you put this in the car section, you'll should get some assistance...... ><////(*>
I thought it was
Either it wasn't and a mod moved it, or you did it right the first time!
WELCOME TO CLUB POLK, please ignore the grumpy old men in the corners. I'll let someone else with more experience in the car audio world answer your questions, but just wanted to extend the welcome. Stick around awhile, there are some great people to learn from here, good luck! -
www.knukonceptz.com/. Best place to get all you wire.polkaudio sound quality competitor since 2005
jonnyBoy101 wrote: »1. I'm planing on rewireing my whole car, i want to knew what wires to get or what is recommend to for polk speakers?
please help,
thanks
So you have C300.2
what else? what other speakers? amps? which sub if any?
Typically 4 gauge power wire and 16 gauge speaker wire is what will work for most applications/installs but it helps to know exactly what you're working with.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
I believe the mods moved it for ya, cause I swear it was under basic hookup/wiring in home audio before (though I could be wrong *shrugs*).
Welcome to CP!..... ><////(*> -
Welcome to CP!
nope. You're just crazy
No I think he is right, lol I think a mod moved it haha,
So what I have in the car is dxi 400 in the front and two kenwoods in the back, the sub is a 12" alphine type E, later after I get more money ima change the ones in the back for Polk, but for now there staying kenwoods lol and an alphine head unit -
I have been in this stuff for a long time. I can say that Rockford Fosgate wire is good, Memphis is FULL size Oxygen free copper, Cadence wire is good too. Budget builds are hard to do, but you get what you pay for in the end. I was in the air about 4 gauge or 0 gauge a couple of years ago, and my installer said" if you go 4 gauge and upgrade later, you will be buying wire twice. Go big or go to the scrapyard!!" I have also used Welding leads as power wire.
