Nice!
VR3
Weller Digital soldering iron arrives tommorow!
Any tips?
Any tips?
Post edited by VR3 on
It should come with one.
:biggrin:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Hehe......:biggrin:Political Correctness'.........defined
President of Club Polk -
Thats funny!
But like if your solder melts at 432 degrees what do you set your iron to?
Im assuming there is an ideal setting for ptp and circuit board...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I usually keep the heat up almost all the way and work very quickly. The only time I may lower it a little is if I'm working on a cheap PCB."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Agreed. I'm usually running about 750 which helps solder flow fast and components not get too warm.
The temp dial turns all the way to the right.
You will get to understand what works for you from using it. For me, around 650 for delicate work, 725 for regular stuff and over 800 when working ground straps and very large terminals. Note a dry tip won't transfer heat. Your solder is the heat bridge. Be sure to keep your tip clean and tinned.
I may have to get one of those solder stations. I'm told my PCB projects would look better if I didn't use this mini torch.
.jpg)
:biggrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
There are a few times I've had to get out the torch for large banana and RCA plugs where I have to heat the entire body.
All I can say is WOW
What a difference. The speed in which the iron heats up and maintains heat under a heavy load is incredible..
Why they make s@#$$y cheap irons is beyond me...
A+++- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
