I need a speaker switch box
Ron-P
I have a very old Marantz SR5000 receiver that does not have a speaker A/B switch. I have a set of Polks in the garage and a second set on the front patio but no way to switch between the two sets. Any idea where I can land one, on the cheap?
I checked Parts Express with no luck.
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
either of these work for you?
http://electronics.mcmelectronics.com/?N=&Ntt=speaker+switch+box
This one at PE too 'spensive for you?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-970 -
These work well, the link below is a fleabay example and can be found elsewhere.
http://cgi.ebay.com/NILES-SPEAKER-SPK-1-LEVEL-A-B-SWITCHER-5-WAY-NICKEL-BI-/160567731184?pt=LH_DefaultDomain_0&hash=item25629523f0Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
could you build your own ?
Ron,
This is where you wanna be. These are the best in the business and very affordable.
http://www.nilesaudio.com/product_selection.php?catcdID=7Dan
I just need something cheap. It's for the garage rig and outdoor rig so nothing expensive. Never thought about building one. I suppose I can check with the Rat Shack for parts. Anyone have ideas on that?If...
Ron loves a film = don't even rent. -
I have an adcom box if you want smething with quality and that is not $$ PM me for details if you are interested.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Great F***ing Switcher - 6 (GFS-6) from Adcom hehehe- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have an older Niles version that can handle 8 speakers...has protection circuit of some sort. It works well but the speaker wire connectors are too close together making hook up a bit cumbersome. Appears their newer models are greatly improved in that area.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Vr3MxStyler2k3 wrote: »Great F***ing Switcher - 6 (GFS-6) from Adcom hehehe
I agree I think the one I have might be the 4 but i think it was rated at 1000 watts or something like that with 12 g. wire in it and takes bananas!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
