Internal Wiring Cable Choices
praedet
praedet Posts: 314
edited April 2011 in DIY, Mods & Tweaks
So, I apologize if there are lots of threads about this, I was not able to find many...
What do you all use for your internal wiring speakers or electronics?
The 3 main decision points are Solid or Stranded, AWG, and Copper or Silver...
For signal cable (I have only wired RCAs and S/PDIF/Toslink) I like semi-fine (22 AWG so far) solid silver.
I have used 16 AWG solid copper for speaker wiring (crossover networks)
I have no idea what internal power cabling should be...
I can say that I really like the silver for internal signal. Anyone else? Also, what "treatment" of the internal wiring is appropriate? i.e. Twisting RCA or speaker pairs and braiding XLR...
Thanks,
Ted
HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure ;)
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
Post edited by praedet on
  • Face
    Face Posts: 14,340
    edited April 2011
    I usually run twisted Neotech 14-18ga inside, but be warned, solid core can put additional strain on the leads.
    VR3 Posts: 29,410
    edited April 2011
    I used 18 ga DH Labs silver plated copper wiring
  • zingo
    zingo Posts: 11,258
    edited April 2011
    DH Labs is fantastic for internal wiring.
    VR3 Posts: 29,410
    edited April 2011
    I really like it and its real easy to work with
    Toolfan66 Posts: 18,016
    edited April 2011
    Where do you buy it??
    nm I will goggle it!!!
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    zingo wrote: »
    That and Kimber's TCSS are my faves for use in electronics.
    VR3 Posts: 29,410
    edited April 2011
    As crazy as it may sound - I found a good source through EBay for about 4 dollars a foot (red/black)
  • strider
    strider Posts: 2,568
    edited April 2011
    I had a recent amp project wired with solid core Neotech for the power input and my father in law chastised me for the way I'd used it. Said it was more prone to oscillation then stranded wire, especially without the negative/positive pairs being twisted. Not having enough to re-wire it in that manner, I ended up changing it out for some mil spec stranded copper PVC insulated wire from a surplus sales company.
    In the end, the type of wire I use isn't the highest thing on my priority list when I'm building something. Not saying the type of wire isn't important, but I feel it's implementation is the make or break of the wiring job.
    Wristwatch--->Crisco
  • praedet
    praedet Posts: 314
    edited April 2011
    Thanks for the recommendations so far guys!
    EndersShadow Posts: 17,702
    edited April 2011
    Thanks for starting this thread. I myself have to wire a CSi5 here shortly and am wondering if I need to use anything other than my Monoprice 14 gauge wire for it.
  • zingo
    zingo Posts: 11,258
    edited April 2011
    Just email Darren from DH Labs and he can sell you stuff direct, or recommend the closest distributor. He's really easy to work with and offers world class products at fair prices.
  • praedet
    praedet Posts: 314
    edited April 2011
    ^^^Thanks
    pitdogg2 Posts: 26,992
    edited April 2011
    Furtech also makes good hook up wire. when i did the XO's on my SDA's I used Furtech through out in 14ga. you can get the different colors for the different wires inside the cabinet.
    FWIW
  • fbm211
    fbm211 Posts: 1,488
    edited April 2011
    Neotech solid 16ga teflon copper.(Soniccraft)
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • zingo
    zingo Posts: 11,258
    edited April 2011
    I'm going to try something new and re-wire my Klipsch Forte speakers with Jantzen Audio solid-core copper PE wire; 17AWG and 20AWG. Obviously I'm hoping for an improvement in sound quality, but if nothing else it will match the Jantzen crossovers in those speakers and get rid of the cheap 80's wiring in the speakers.
  • drumminman
    drumminman Posts: 3,396
    edited April 2011
    It's $2.49/ft in less than 100 ft increments. Just did the internals on both my RTA 12C's when I reworked the crossovers.
    I can't tell exactly what effect the wire has had on the sound since I changed so many things as once. :tongue:
    It's not too expensive and I like the looooooooong crystals it has! :biggrin:
  • praedet
    praedet Posts: 314
    edited April 2011
    ^^^Sounds good!
