New to home theater
Yamaha RX-A3000 Receiver( a bit overkill ). Room size 13' x 13'. I have a $600 credit at Newegg and they sell Polk speakers.
What is the difference between the TL2 and TL3 system ? Is it worth the extra money for the TL3s? If i go with the TL2 is it better to buy the 550WI subwoofer or go with the TL2600 package?
Post edited by possinger on
I can not reall comment on the TL2 vs TL3. Te tl3 is better but I have heard nothing but great things about the TL2's. In regards tot the sub I would deffinetly get the 550WI. It will blow the doors off the package sub.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
The TL2 uses the tweeter from the RTi-A series...the TL3 uses the ring radiator tweeter from the LSi series.
I haven't heard either, but I'd imaging the TL3 would be a considerable upgrade.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
I have not heard the TL2 but walked into distributor the other day it was very quiet except the music they had on spun around in circles a couple times trying to figure where the music was coming from....it was coming from the TL3's they had perched on the counter .....was very impressed2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Thanks for the info. I'm going to Best Buy or Greegs to give a listen, but i hope to get some more replys.
