New to home theater
possinger
possinger Posts: 3
edited April 2011 in Speakers
Yamaha RX-A3000 Receiver( a bit overkill ). Room size 13' x 13'. I have a $600 credit at Newegg and they sell Polk speakers.
What is the difference between the TL2 and TL3 system ? Is it worth the extra money for the TL3s? If i go with the TL2 is it better to buy the 550WI subwoofer or go with the TL2600 package?
  • packetjones
    packetjones Posts: 1,059
    edited April 2011
    I can not reall comment on the TL2 vs TL3. Te tl3 is better but I have heard nothing but great things about the TL2's. In regards tot the sub I would deffinetly get the 550WI. It will blow the doors off the package sub.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • mystik610
    mystik610 Posts: 699
    edited April 2011
    The TL2 uses the tweeter from the RTi-A series...the TL3 uses the ring radiator tweeter from the LSi series.
    I haven't heard either, but I'd imaging the TL3 would be a considerable upgrade.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    txcoastal1 Posts: 13,520
    edited April 2011
    I have not heard the TL2 but walked into distributor the other day it was very quiet except the music they had on spun around in circles a couple times trying to figure where the music was coming from....it was coming from the TL3's they had perched on the counter .....was very impressed
  • possinger
    possinger Posts: 3
    edited April 2011
    Thanks for the info. I'm going to Best Buy or Greegs to give a listen, but i hope to get some more replys.
