Entry level reciever
elb2392
Hey guys,
So I need to get a receiver that will power my RtiA3's, CsiA4, and Mirage subwoofer. I do not want to spend a lot of money on this, I am already over budget as is for a broke college student... The receiver will be used with my Sony XBR 46inch LCD tv, bluray player, as well as xbox 360. Please let me know what you guys think. Again, I REALLY dont want to spend a lot, just need something that will sound good and work.
Cheers
Cheers
Post edited by elb2392 on
Sound good AND entry level receiver kinda are at opposite ends of the pond.
Whats your idea of cheap ? Give us a dollar range. You may be better off going used to stretch the buck. Look for a used pioneer elite, HK, Marantz, Lots of choices in the under 500 buck range for entry level receivers, and pretty much all will drive those speakers.HT SYSTEM-
lsi 9's -
HONESTLY, the cheapest possible. Sub 3 hundred if possible. I know that wildly cheap, but its all I can afford!
http://www.amazon.com/Pioneer-VSX-521-K-Theater-Receiver-Glossy/dp/B004M8RPAY
For another hundred you can get the 8212-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Also check your local craigslist, you may come up with stuff like this.
http://chicago.craigslist.org/nwc/ele/2337880295.htmlHT SYSTEM-
lsi 9's -
Pioneer vsx 1020- used but only 329 with free shipping is a good deal.
http://www.amazon.com/Pioneer-VSX-1020-K-Home-Theater-Receiver/dp/B0039XQQX0/ref=sr_1_1?s=aht&ie=UTF8&qid=1303476423&sr=1-1
Here's a new Onkyo.
http://www.amazon.com/Onkyo-HT-RC260-7-2-Channel-Theater-Receiver/dp/B003FSTAVY/ref=sr_1_6?s=aht&ie=UTF8&qid=1303476594&sr=1-6 -
HK 24hr auctions on ebay is a good way to score a 2xx series that sounds great for ~ $250.00. They make a fine starter pre/pro as well since they have preouts.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
ken brydson wrote: »
Or here: http://www.polkaudio.com/forums/showthread.php?t=118748
$50 over budget I guess, but a nice AVR.Things work out best for those who make the best of the way things work out.-John Wooden -
Like others have mentiomed...used is the way to go...more bang for your buck!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Check Best Buys open box section. I got a Pioneer 1020 for $329 last month. For the money it's a great receiver.
My 5.1 Pioneer 819H powers 2 RtiA1's, a CsiA4, and 2 Polk TL3 surrounds quite nicely in a 16x18x 9 foot ceiling room that has large openings on all 4 walls. My HSU subwoofer, like yours I expect, doesn't require any "power" other than it's own. The Pioneer nevers gets above warm to the touch. Going to a more expensive 7.1 receiver doesn't necessarily give your more power TO each speaker. It just gives you the ability to power 7 speakers instead of 5. I had some extra money to spend recently and went into Best Buy to buy a bigger, "better" AVR. The very knowledgeable salesman told me I was throwing money away and sent me home with my money.
Got my Onkyo refurb from this place about 3 years ago. Still works great.
Onkyo 608 is a good deal right now:
http://www.accessories4less.com/make-a-store/item/ONKTXSR608/Onkyo/TX-SR608-7.2-Channel-3-D-Ready-Home-Theater-Receiver/1.html~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox
