Sub to compliment my full Lsi system?
I am shopping for a sub, or two, to go with my LSi hometheater setup. I have limited space for placement up front as you can see in the pic.
Use will be 70% movies/20% games/10% music
I do have space to the left and right beside or behind the couch in the rear of the room. If I were to locate the sub to the rear of the room I would need it to be wireless as I have no more room to hide wires behind the baseboard.
Any recommendations that would work in my situation and pair well with the LSi's?
Thanks!
Thanks!
Front Stage
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
Pioneer VSX 1120 receiver
PS3
Epson 8350 Front Projector
110" screen
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
PS3
110" screen
What is your budget and room size?Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I have a similiar system, using a Polk micropro 4000, outstanding and the piano black finish match the LSI 15, and LSIC.Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
Thanks!
VELODYNE OPTIMUN
http://www.velodyne.com/vproducts/docs/Optimum%20datasheet_web.pdf -
Budget is around <1000
Room size is 12x16x9Front Stage
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
PS3
110" screen -
Dual Epik Legends would sound nice in your room and it fits your budget.
I have a Polk LSiW, now called the PSW1000, and it works great with my 4 LSi15s. I have it in the center in front of the TV. This works out great since it has speakers on either side versus one in the front.
Find a used PSW1000 and add it. A suggestion would be find a stand to allow the center channel to be higher, and near the bottom of the picture.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I realyy like the sound of the micro pro series as i have 2 now and want to get 2 more in the future. The bass is tight and quickYamaha rx-a2000 AVR
Polk csi5 Center
Polk rt16 Main
Polk fxia6 Rear Surround
Paradigm Micro Rear Back
Onkyo bookshelf Front Presence (for now)
PSW 450 Front Sub
DSW MicroPro 4000 Front Sub
DSW MicroPro 2000 Rear Sub
Samsung c6300 60 inch LED
Sony BDPs370
Room Size 15x30 -
Epik Legend is what I'd getTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
One more vote for the Micropro 4000!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Plus that. I'd also have to give a nod to trying out dual Outlaw subs, I love my single + and I'm always looking out for a second. I figure, per WAF factor, that we should have two matching end tables. :biggrin: -
I would get the biggest sub you can for the budget. There is simply no replacement for displacement. For movies you don't care so much for tightness or quickness as you do for output and slam. Not that those factors aren't important, it's just the latter factors I mentioned are more important for your needs. For this reason, I would personally stay away from the smaller Polk or Velodyne subs.
You don't necessarily need to "match" a sub to your mains, any sub would pretty much do if placed correctly and you set the XO to blend in well. Of course with an EQ this is all accomplished much better. I tend to sway toward SVS for HT, or even EPIK, but Elemental designs has some great offerings which would beat SVS for bang for you buck. SVS has great subs, no doubt, I've owned three, but their new prices aren't as great as eD's for bang for your buck IMO.
http://www.edesignaudio.com/product_info.php?cPath=2_41&products_id=618
Epik's Empire is also in your price range, and people love it for movies due to the midbass slam, but it has less output down low, but due to your room size, it can probably reach down deeper and have plenty of output all around. However, after shipping it comes around at 1k. Two legends a little more.2Ch Tube Audio Convert -
All look like great options, however, they will not work for the front of the room due to the dimensions.
Are wireless adapters even worth looking at paired with, eD, epik, or velodyne offerings?Front Stage
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
PS3
110" screen -
Polk has wireless options, and plenty of good wired options too. You're here, why look elsewhere? DSW Pro or Micropro and you're done, and messing your flat hat.
Cheers,
Velodyne has a new wireless sub.
I have a demo of a Polk DSWPro500Wi and it is a gem. If wireless is the best option, try a pair of those. They fit the budget. You may be surprised. -
You can get a 3rd party wireless adapter anywhere to use in conjunction with any sub. I know Outlaw and Hsu offer them on their subs. I'm not too familiar with the topic so hopefully someone can help you out there. As far as I know, they work the same audibly as a wired connection. It's a little costly however. Which Velodyne were you specifically looking at?2Ch Tube Audio Convert -
Conradicles wrote: »Velodyne has a new wireless sub.
I hate what Facebook has done to me, I read this post and wanted to click 'Like' but alas, it isn't there.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Cheers,
Russ
Polk subs will be alright for music, but for HT, you can certainly do better. The majority of Polk subs roll off SUBSTANTIALLY by 20hz. For movies, you'd want more output and extension which Polk subs can't do as well as others. Since your priorities are toward HT, the bigger the sub, the better. A bigger sub will be able to extend much lower than a small sub. Small subs are compromises, and you don't want that.2Ch Tube Audio Convert -
You can add two big subs and they don't have to be on the front wall. You can place them on the side walls. Give this link a quick read and you'll find some choices other than all on the front wall.
http://forum.blu-ray.com/subwoofers/43669-guide-subwoofers-part-i-characteristics-placement-adjustments.html
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
