burying Bose cubes in walls
leftwinger57
Hello again, I just need another opinion here of a practice of the co. I used to work for. We were primerily a high end alarm / security co. that branched out to become a Bose distributer. Now I've install the Lifestyle 30s and 50s and for some houses they were fine. For much bigger houses we installed these 3-room amps in the basement of most houses. These amps if you don't know look like car amps w/ the ability to handle 3 rooms and then be bonded to fit more amps depending on how much the customer wanted.
One customer did not want the cubes to show on a Lifestyle 50 system so we had to make an internal shelf to hide the cube to be covered by a common
flush type grill cover. Keep in mind all this work was pre-wired and then when they closed we finished up.
I don't know if any of you guys have heard of this technique and have an opinion either way. I am retired now and away from the co. for 9 yrs if that matters.......LW
I have heard of people doing this with all kinds of small bookshelf and mini speakers. At least until they started making in-wall speakers that actually sounded good.
It is moot now with in-wall fronts, centers and subs that are designed to disappear into the aesthetics of the room and sound great doing it.
I still prefer regular speakers so the compromise is not worth the sonic loss to me. -
I prefer burying them in the back yard...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I prefer burying them in the back yard...
You beat me to it !! :biggrin:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
not worth the time spend with a shovel.
and honestly any box speaker then placed into a wall will change the speakers performance. So normally its not recommended and to rather go with another type of inwall speaker.
Also I don't think you can take the gril off the bose so you would have two grills then the speaker is playing through. Once again can change things... -
I humbly disagree with all of the above, except the shovel part, as my dog will bury them for me.:biggrin:
If you use MIT Oracles... http://www.mitcables.com/available-online/oracle-v3.3-speaker-cable.html
...these speakers really shine and sound better than any other speaker I have ever heard. It is actually beneficial to have two grills covering the speaker because otherwise they would sound so lifelike that your brain could not process the illusion and would turn to mush.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I have a pair of Bose 301,s ( bought before I knew better) I plan on putting them in the fireplace on a cold evening, at least the room will be heated for an evening.......................................................Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
Thanks guys , remember this was not my idea, I did have bosses and the home owner
always had the last say whether they were right. the boss would satisfy the customer for the sale.....LW2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
:biggrin:....was going to say that the first three words of the title were appropriate without the rest....____________________________________________________________
