Can I control volume of dialog audio and sound effect/music?
BellaLuna
BellaLuna Posts: 12
edited April 2011 in Speakers
My set up: Blu ray hdmi to mitsubishi wd60c10 dlp tv hdmi, Mitsubishi tv coax to digital optical converter to digital optical cable to IHT 6000.
I am having problem with controlling the dialog audio volume and sound effect/music volume. When I was watching few movies, I set my volume to where I can hear the dialog audio clearly and all of the sudden in the movie, stuff started blowing up with the music and holy jesus IT GETS REALLY LOUD. Is there a way to control this seperatly oor othe ways? If I set my volume lower to reduce the sound effect/music, its hard to hear what they are saying. But holy cow
Post edited by BellaLuna on
  • slk55amg
    slk55amg Posts: 305
    edited April 2011
    adjust your receiver speaker settings, run your center + 1-2db that will solve it
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2011
    Doesn't look like he's running it through an AVR...so to answer the question...no.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2011
    You can go in your BluRay's menu and set your dynamic range setting to "night" or "limit" whatever your player calls it to reduce dynamic range. This will reduce dynamic swings giving the illusion that dialogue is more level with music/effects.
    I have my panasonic dmp-bd30 setup to limit dynamic range, for the same reasons. Apparently "wow factor" is more important than listenability anymore. I have a 2-channel HT.
  • BellaLuna
    BellaLuna Posts: 12
    edited April 2011
    It seems like I only have one option on the audio setting. I have Sony BDP-BX37
    Audio DRC Setting:
    1. Auto- Performs playback at the dynamic range specified by the disc(BD-Rom only) other discs are played back at the "standard" level.
    2. Standard- Performs playback at a standard compression level.
    3. Wide range- No compression works. A more dynamic sound is produced.
    Which one do I need to select? Thank you for all the replies :)
  • steveinaz
    edited April 2011
    #2, "Standard". I'm assuming "DRC" means Dynamic Range Control.
    Give it a try and see if this helps.
    On my panasonic it says "Dynamic Range Compression" and you select "enable" or "disable." During concerts or music I disable compression, but during movies I use compression to correct overly loud effects.
    tonyb Posts: 33,069
    edited April 2011
    His tv may also have some sort of dynamic control since he's basically routing it that way. Thumb through the menu screen for the tv and see if anything is available.
  • BellaLuna
    BellaLuna Posts: 12
    edited April 2011
    You guys are genius. Standard mode worked. I could control more sound from blu ray digital optical to sound bar than tv to sound bar. Thank you
  • steveinaz
    edited April 2011
    Good deal.
  • ken brydson
    ken brydson Posts: 8,996
    edited April 2011
    BellaLuna wrote: »
    That might be a stretch....:biggrin:
