Isolation tweak--affordable too
george daniel
Just saw these on another forum--kinda looks like the "Mapleshade" ones,,anyhow,,I might try some out.
http://www.alpinehomeair.com/viewproduct.cfm?productID=453058383
Post edited by george daniel on
Price seems right. Wonder how much an air handler or furnace weights. 60 pds?Speakers: SDA-1C (most all the goodies)
I use some very similar with great results. All my gear sets on them and some of the gear gets 1 or 2 on top to further reduce vibration. Nice...
Yeah, I got lucky and my dad got me some rubber stoppers from his work that are about 1 1/2 inches around, 1 inch tall and taper down to about 1/2 an inch at the top.
They work great as spacers for my gear and vibration isolators..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Sounds like a sort of "subdude" tweak. I'm not so sure how much it will help with sound quality when isolating components but usually any stiff enough closed cell foam would do the trick. I built my own subwoofer isolation platforms with some locally purchased foam with great effects.
As for using rubber stoppers, rubber seems to transmit a lot more vibration than foam does.2Ch Tube Audio Convert -
I wonder what the weight rating is for those? Good find.
Price seems right. Wonder how much an air handler or furnace weights. 60 pds?SolidSqual wrote: »I wonder what the weight rating is for those? Good find.
60-80 pounds?Speakers: SDA-1C (most all the goodies)
Word of caution. Some of these will leave a black mark that is near impossible to remove on wood surfaces when left in one spot for periods of time. Not sure if this particular one does that, but a forum member was kind enough to offer me a set that looks similar and I learned of this the hard way. Just an FYI.
It's like some sort of chemical or oil type substance leaks or gets absorbed into the wood grain itself. That would be the best way to describe what happened with the ones I have. Other than that, they work good.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I've found some Bright Star Audio bumpers leave a greasy, hard to remove mark as well. I'm not a big fan of them from any manufacturer.
As far as the suggestion here, used them for years with no issues but never really thought about it. I'm sure Treitz had grounds so take that with a grain.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
My guess is that most of those isolators are all made by the same company as they all look very similar. It probably doesn't matter where you buy them, just find the best price.
I recently got a set of the Sorbothane feet to put under an amp for isolation. They are really a nice product even though they can't hold as much weight as a rubber/cork compound. Because of their nature, they are self-adhesive, but can also leave a residue on wood like rubber based products. The oils used in Sorbothane may damage some wood finishes over time. Therefore it is recommended that using something underneath the foot to prevent the transfer of the oils; I.E. Small piece of Cellophane, Mylar, etc. Probably good advise for any similar products.
