What Wire? RTi A5's & Pioneer Elite VSX-33
4WardMotion
4WardMotion Posts: 36
Well, I'm new to this arena and need a little guidance. I just purchased a pair of RTi A5's and I'm getting ready to order the Pioneer Elite VSX-33. I don't have a whole lot of money left to spend, but would like to get some decent speaker wire for my system. What would you recommend as good speaker wire to start out with for my set-up?
Thanks for the help!
4WardMotion
Post edited by 4WardMotion on
    F1nut Posts: 51,915
    edited April 2011
    How much $?
  • 4WardMotion
    edited April 2011
    Well, I would say $50 to max $100. I really would prefer to stay around the $50, but if going up to $100 will make that big of a difference, I am open to suggestions. Thanks!
    F1nut Posts: 51,915
    edited April 2011
    In that price range, it won't make a difference. Get whatever strikes your fancy.
  • danz1906
    danz1906 Posts: 5,144
    edited April 2011
    Audioquest
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • mantis
    mantis Posts: 17,557
    edited April 2011
    I'm assuming your going to finish out the speaker package and go full surround? If that's the case or not I suggest Audioquest FLX14/2 speaker wire. It's very affordable and is the best sounding 14g wire I have ever used. You can pick it up here for a great price.
    http://www.crutchfield.com/p_703142125/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-125-feet.html?tp=1432
    Dan
  • 4WardMotion
    edited April 2011
    Thank you for the feedback!
    Yes I plan to finish out the system with a sub, center and surround. I will go check out the wire that was recommended. I appreciate the help here as I am new to all of this.
    Thanks!
    4WardMotion
