20 amp circuit stress limit?
digitalvideo
digitalvideo Posts: 983
I would like to install a 20 amp dedicated circuit on 12 awg wire. What is the max watts it can handle or what should be a safe amount to not stress it?
This is what I will be plugging into that circuit:
Pioneer Elite SC07 reciever
Pioneer Elite 23FD bd player
SVS PB12 Ultra sub
Comcast HD cable box
And would the SurgeX SX1120RT surge protector be able to handle and protect that, would I be stressing it or is it well within it's limits?
http://www.surgex.com/products/sx1120rt.html
Post edited by digitalvideo on
  • jinjuku
    jinjuku Posts: 1,523
    edited April 2011
    20 Amp circuit for what you listed is no problem. That is a 2400 watt circuit.
    SurgeX makes a great product and the one you listed will have no problems.
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited April 2011
    The electrician's rule of thumb is that a 20amp circuit should carry no more than 1920watts of continuous load. You don't have anything to worry about if you have a dedicated 20amp circuit with just that equipment on it. If you're concerned you could get a Kill-a-watt and put it between your surge protector and the wall outlet and see what the max is. After that experiment though, I would just plug the sub into a wall outlet. Plugging it into a surge protector will make it work less good.
  • digitalvideo
    edited April 2011
    jinjuku wrote: »
  • digitalvideo
    edited April 2011
    On3s&Z3r0s wrote: »
    On3s&Z3r0s wrote: »
    SurgeX is a professional audio surge protector used by professional recording studios to lower the noise floor, also some members at avsforum.com have done testing with SurgeX products and found the same results with improved SQ and lowered noise floor. Are you sure a SurgeX will hurt the SQ of a sub or are you refering to the more common mov based surge suppressors like APC, Monster, Panamax, Triplite? SurgeX doesn't use mov's, it uses Advanced Series Mode, and has EMI/RFI filtering.
  • On3s&Z3r0s
    edited April 2011
    I would try it both ways (sub on surge protector and direct to wall) and see if you have any preference. I personally don't think a subwoofer is delicate enough to need to be on a surge protector, and surge protectors typically don't help sound quality when it comes to the low end.
    treitz3 Posts: 19,947
    edited April 2011
    DV, the lowered noise floor as far as I have observed, has only been on the mid to upper frequencies. I would plug the sub directly into the 20 amp outlet and the rest into the SurgeX and call it a day.
    You would not be stressing it, enjoy.
  • digitalvideo
    edited April 2011
    Ok, thanks...
    Could I add on another second SVS PB12 Ultra sub onto that circuit or is that pushing it?
    I don't know if I want to plug the second SVS sub in the opposite corner of the room in a seperate dedicated 20 amp circuit or plug it into the same circuit with all the other electronics listed above and connect a long wire around the room, either way the second sub will be in the opposite corner of the room.
    It would look like this on one circuit:
    SVS PB12 Ultra sub
    SVS PB12 Ultra sub
    And would the SurgeX SX1120RT handle that?
  • maxima
    maxima Posts: 143
    edited April 2011
    DV,
    You should have no issues adding another PB12 to this 20A circuit.
  • jinjuku
    edited April 2011
    Ok, thanks...
    I run my equipment stack off of a 20 amp circuit and have never tripped it. That includes (see my sig) a Behringer EP2500 pushing two subs, AVR, Adcom GFA 5503, TV, X-Over.
  • digitalvideo
    edited April 2011
    Ok, thanks everyone.
  • mufsoman
    mufsoman Posts: 636
    edited April 2011
    My house is wired with all 10 amp circuit breakers, except for furnace and AC. I have all my equipment plugged into one circuit and have never tripped the breaker. I'm planning on running dedicated circuits eventually
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited April 2011
    I am running all what I have in my signature and a 750watt power supply in my computer. Never had any problems.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
