Importance of speaker wire length for HT
polkfarmboy
I ordered a bunch of mit exp2 for music and HT and wondered how important it is to keep the wires the same length
For my front sound stage I was going to have 3 10ft runs to keep it all the same . Well I just rearranged the room and now it is only possible to get to the amplifier with 2 of the 10ft's so I may have to use a different size for the front right speaker
Is this going to make a difference in sound quality of does my preamp sort this out if I run the auto cal ?
I may now have to have everything wired at diff lengths to compensate for the way I rearranged
Post edited by polkfarmboy on
polkfarmboy wrote: »I ordered a bunch of mit exp2 for music and HT and wondered how important it is to keep the wires the same length
If your OCD, you must have every piece of wire the same length. If your a normal person, use what you have. By the way, I'm OCD and all my wires are the same length in my 2 channel rig. I'm not as OCD on my HT.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
If you're looking to get rid of an extra 10ft let me know! I bought a pair and need a single for my center.
Sorry brun I already promise that spare 10 to juan -
Right on, I might just have to buy another pair and hope I can sell one. Thanks anyways and good luck with the wires man.
