Importance of speaker wire length for HT
polkfarmboy
polkfarmboy Posts: 5,703
I ordered a bunch of mit exp2 for music and HT and wondered how important it is to keep the wires the same length
For my front sound stage I was going to have 3 10ft runs to keep it all the same . Well I just rearranged the room and now it is only possible to get to the amplifier with 2 of the 10ft's so I may have to use a different size for the front right speaker
Is this going to make a difference in sound quality of does my preamp sort this out if I run the auto cal ?
I may now have to have everything wired at diff lengths to compensate for the way I rearranged
Post edited by polkfarmboy on
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2011
    If your OCD, you must have every piece of wire the same length. If your a normal person, use what you have. By the way, I'm OCD and all my wires are the same length in my 2 channel rig. I'm not as OCD on my HT.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • B Run
    B Run Posts: 1,888
    edited April 2011
    If you're looking to get rid of an extra 10ft let me know! I bought a pair and need a single for my center.
  • polkfarmboy
    edited April 2011
    B Run wrote: »
    Sorry brun I already promise that spare 10 to juan
  • B Run
    B Run Posts: 1,888
    edited April 2011
    Right on, I might just have to buy another pair and hope I can sell one. Thanks anyways and good luck with the wires man.
