DORO....Question on Delphi XM
steveinaz
The Monster cable IP400 cable you showed in an earlier post(mini-stereo to RCA); it doesn't get in the way of the antenna and power connectors on the home cradle?
Post edited by steveinaz on
Steve - I don't have the home cradle, only the car mount. If you snap me a pic of the side I can tell you whether it will fit....
It is 3/4 inch wide....then tapers into the miniplug. The thickness is about a 1/4 inch....that help?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Yep, that will help. I'll measure it when I get home, but I don't think it will fit. Why Delphi put the 3 connectors so close together, I'll never know...
Thanks bud for the quick response.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Anytime honcho.... They probably made it proprietary, so we would have to buy the high speed, extra special, Delphi only adapter
..the supplied cable is like fishing line with connectors soldered on..LOL!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Steve,
I borrowed my brother's Delphi XM setup with the home cradle for a week and I used the Monster IC that Doro helped me find.
No problems with the fit. AR also makes a cable. You can find both at Best Buy if you have one near you and yes the stock cable is a joke.
Paul -
Coolness...well there we go, mystery solved
Thanks all! I appreciate the help.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The following are model numbers for mini stereo jack to 2 RCA jacks (Delphi XM home cradle upgrade IC):
Acoustic Research: AP042, 3ft
Monster: IP200, 1 mtr; IP400, variable lengths from .75 mtr
Cost (approx):
AP042....$12.00
IP200-1M....$18.00
IP400-.75.....$34.00Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Ensure that you check Ebay and Half.com....I picked up the MC IP400 for like $10 used. Good information Steve!CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
