DORO....Question on Delphi XM
steveinaz
steveinaz Posts: 19,538
edited February 2004 in Electronics
The Monster cable IP400 cable you showed in an earlier post(mini-stereo to RCA); it doesn't get in the way of the antenna and power connectors on the home cradle?
Post edited by steveinaz on
  • dorokusai
    dorokusai Posts: 25,577
    Steve - I don't have the home cradle, only the car mount. If you snap me a pic of the side I can tell you whether it will fit....
    It is 3/4 inch wide....then tapers into the miniplug. The thickness is about a 1/4 inch....that help?
  • steveinaz
    Yep, that will help. I'll measure it when I get home, but I don't think it will fit. Why Delphi put the 3 connectors so close together, I'll never know...
    Thanks bud for the quick response.
  • dorokusai
    Anytime honcho.... They probably made it proprietary, so we would have to buy the high speed, extra special, Delphi only adapter :D
  • steveinaz
    ..the supplied cable is like fishing line with connectors soldered on..LOL!
  • pjdami
    pjdami Posts: 1,894
    Steve,
    I borrowed my brother's Delphi XM setup with the home cradle for a week and I used the Monster IC that Doro helped me find.
    No problems with the fit. AR also makes a cable. You can find both at Best Buy if you have one near you and yes the stock cable is a joke.
    Paul
  • dorokusai
    Coolness...well there we go, mystery solved :D
  • steveinaz
    Thanks all! I appreciate the help.
  • steveinaz
    The following are model numbers for mini stereo jack to 2 RCA jacks (Delphi XM home cradle upgrade IC):
    Acoustic Research: AP042, 3ft
    Monster: IP200, 1 mtr; IP400, variable lengths from .75 mtr
    Cost (approx):
    AP042....$12.00
    IP200-1M....$18.00
    IP400-.75.....$34.00
  • dorokusai
    Ensure that you check Ebay and Half.com....I picked up the MC IP400 for like $10 used. Good information Steve!
