Would HDMI sound better?
TennMan
I have a Pioneer receiver that has an HDMI 1.4 input for a DVD player. I also have a Pioneer DVD player with an HDMI output. I currently use the RCA audio cables between them. I'm using this mainly for 2 channel listening to music with an occasional movie. I only have two monitor 10b speakers. For better sound, should I get an HDMI cable to use instead of using RCA cables?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Post edited by TennMan on
it all would come down to which has the better DAC. The DAC in the CDP could be a better DAC in the AVR thus you would want to keep it where you are at now.
I would says the Pio you have for the AVR is more of an entry level one and I don't have any experience with the DVD player. I would say that if its a more entry level you would be able to leave it where you are at right now and would be just fine as you probably wouldn't notice a difference between the HDMI and the analog outs on the DVD player. -
+1, cstmar01.
What people usually do is run the equipment both ways and see 'which' way sounds 'better' to them for 2 channel. That said...I suspect there will be little difference.
You'd be better off investing in a decent mid-level CDP such as the Marantz 5004 for 2 channel? And keeping the Pioneer DVD for movies.
Thanks for the replies. I'll try that.What people usually do is run the equipment both ways and see 'which' way sounds 'better' to them for 2 channel. That said...I suspect there will be little difference.
cnh- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
