need info on Technics SU-V9 integrated amp
danger boy
danger boy Posts: 15,722
edited July 2012 in Electronics
a seller has one of these for sale.. $40. says it's minty looking..
anyone know anything or ever own one of these before?
Technics SU-V9 silver early 80's 120wpc integrated amperage....
i read somewhere that someone thinks it's a class A amp :confused:
someone shed some light on it if possible. DC amp? what the heck is that.. with a button that says.. straight DC ??
su-v9-h.jpg similar to this one
PolkFest 2012, who's going>?
Post edited by danger boy on
  • danger boy
    edited April 2011
    i found this link about this amp http://audio-database.com/TechnicsPanasonic/amp/su-v9-e.html
    the translation from Japanese to English sure makes for an interesting read :wink:
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited April 2011
    Can't go wrong for $40.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • gfong
    gfong Posts: 1,079
    edited April 2011
    I ran one back in 80's! Very nice class A amp. Powered my Klipsch LaScala's perfectly. Never broke down, ample power, very clean power.
    Straight DC mode was running it flat with out internal filters or tone (bass/treble) controls.
    Before I settled on my LaScala's I used it to power 2 Bose 901's and 4 Bose 601's. It ran quad no problem and no heat issues. I also tried a pair of 15 inch Cerwin Vegas.
    Of course at different times, as I was trying to find the right speaker to settle on! :)
    I had the black finish, but same amp.
    If you pass on it please forward me the contact! :)
    edited April 2011
    I picked up a Technics SU-V78 integrated and it's matching tuner for about $20 at the local Goodwill a few weeks ago. It is also marked New Class A on the front but your model is the more powerful and better built. Cerca late '80s, I think?
    This integrated is not a true class A but uses some circuit configuration where it keeps everything on rather than 'switching' like a normal AB push pull. Don't ask me much more about this because I've only seen a page or two in some 'archive', and I suspect it goes AB at higher power. It has an auto fan in the back that only comes on when you push the unit.
    That said. I definitely think these units are worth the low prices. I might negotiate a few more dollars down, but if it's in good condition, hey.
    I've been running mine with my monitor 5s and I've been pleasantly 'surprised'--it's not the best thing of course but for 15-20 dollars--try and find something 'better'. I think mine is probably 75-80 watts x 2, but it draws 350 watts according to its backside?
    I'd say give it a shot and see what you think.
    cnh
  • gfong
    gfong Posts: 1,079
    edited April 2011
    Amp is from 1981/82, a bit different then the V78 that came out in 86 and ran to 88.
    heiney9 Posts: 25,431
    edited April 2011
    Can't go wrong for $40, it's not really Class A............it's one of those pseudo-marketing terms they used a lot in the 80's.....it's called "New Class A". It's a typical sliding bias scheme with a fancy marketing name.
    Nice stuff for the price. I always liked the Technics stuff from that era. I think it sounded pretty good compared to the other major brands of the day.
  • megasat16
    megasat16 Posts: 3,521
    edited April 2011
    Worth every penny of $40 for that Integrated. It's not real Class A but it is New Class A.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • megasat16
    edited April 2011
    danger boy wrote: »
    Me thinks DC means direct coupling and it bypasses all signal line capacitors. (i.e, if pressed, me thinks it bypasses all the tone control circuitry which uses capacitors too).
  • danger boy
    edited April 2011
    Well I did pick it up.. looks to be about a 8.5 out of 10 on condition. Built in the early 80's.. circa 81 to 83'
    the seller had it hooked up to some older Yamaha towers.... and it pushed them without any problem.. and actually sounded quite good.. despite having the treble cranked to 9 on the dial.
    I'll hook it up to my SDA 2B's and see what happens. I think it's just a middle of the road sounding amp.. but it appears to really have some power behind it..
    I was attracted to it's power abilities.. thing is pretty heavy.. maybe I should look under the hood and see what kind of large power supply it has :wink:
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    I had an SU V6 back in around 81 which was from the preceeding series of dynamically biased Quasi Class A amps.(IIRC the V9 replaced the V8).It looked nice IMO ,was well built and had excellent spec's on paper but thats about all it had...I replaced with a less expensive ,lower powered and poorer spec'd NAD 3020B.My ears thanked me.
    gudnoyez Posts: 8,161
    edited April 2011
    Buy it danger boy see my man cave set up! I own one in silver still in service as we speak, and one in dark gray which is out of service,very heavy amp was dropped,but will refurbish when I get the extra funds. The one I run right now has been in service since 1983 and still pushes any speakers you hook up to it. I would buy it if I could well worth the $40. I see you did buy congrats you will be happy you did.
  • danger boy
    edited April 2011
    well the amp works ok... some of the knobs and buttons have some static.. so needs a good cleaning and conditioning on those. amp has plenty of power behind it. I couldn't go over 3 on the dial with the turntable.. and only about 2 with the CD player.
    I have to say.... it sounds pretty decent.. yeah it's never going to compete with better made and well known amps with the same power.. but as long as your CD player or turntable are on par.. I'll be able to enjoy the amp for now... and yeah it's heavy. I want to open it up soon and take some gut pics..
  • danger boy
    edited April 2011
    that amp seems a bit bright to me.. which for my ears isn't to bad.. but on some CD's.. it can be to much of a good thing.
    I figure for $40 it was worth a gamble... with laid back speakers.. this amp would prob do ok.. just impressed with how much balls this thing has.. big cajones! :tongue:
  • megasat16
    edited April 2011
    You can flip that int amp on the bay for north of 100 anytime you want. $40 is no a brainier.
  • marly421
    marly421 Posts: 73
    edited July 2012
    The seller is clueless. $250 would be closer to real value. Stealing it for $40 (you should try to check to see if it isn't stolen). I own two of them and both are near perfect reproducers. Couldn’t find anything better sounding up to about $1500.
