CSi5 with R50's
CBrischler
Will a CSi5 center sound OK with R50 front speakers... presently have a CS245i center but want to upgrade to 6" drivers in the center. I think the CSi5 is matched to the RTi series more closely but will using it with the R50's sound good.
Buzz
Buzz
Post edited by CBrischler on
Nobody has had a center and front mismatch??? Do you think it is better to be mismatched with the center being more brillant than the fronts as this setup will be. As the center seems to be mostly midrange voice etc I am thinking it will not be that big of a deal. Thoughts would be appreciated/
Buzz
