Chemistry Question
Serendipity
I have some homework due next Tuesday, and not remembering *anything* from high school chemistry, was wondering if any chemists here could explain the following to me:
The Donor concentration in Si crystal is 1017cm-3. Assume complete ionization. Temperature is 300K. At the moment t=0 the 1016cm-3 of excess electrons and holes were generated. Find the position of the electron quasi-Fermi energy with respect to conduction band edge. Find the position of the hole quasi-Fermi energy with respect to valence band edge. Compare to the position of the Fermi energy in equilibrium (before generation of the excess carriers).
I just want to let everyone know that I am NOT looking for just the answer, as it is useless when it comes time for the exam, but would rather know how to solve the problem. I'd GREATLY appreciate it if anyone could give me ANY advice on these, and will say thanks in advance.
- Serendipity
- Serendipity
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
I find that my two channel rig helps me solve problems just like this one. Have you tried that yet?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The crux of the biscuit is the apostrophe :biggrin: Does that help any?
Select "E" One of the above.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
The heat of the meat is directly proportional to the angle of the dangle,or something like that !!!!!!If you can't hear a difference, don't waste your money.
Always amazes me that people come here for academic advice. Kid, read your book, read your notes, and work out the problem. That's the way we all did it back before the internet. BTW, I don't think any High School chemistry would help you in that problem.
I think I got a headache just reading that.
joeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Word! :biggrin:Testing
Testing
Testing -
this will get you going..... good luck on the exam
fc(k,r) conduction-band state
fv(k,r) valence-band state
ni(Tn) thermal equilibrium if Fermi level at Ei & temp Tn
pi(Tp) thermal equilibrium if Fermi level at Ei & temp Tp -
AudioGenics wrote: »this will get you going..... good luck on the exam
Ok, I got this assignment back and apparently answered the question wrong. I guess it's not a simple "substitute and solve" kind of question I was hoping for...polkaudio RT35 Bookshelves
Does this mean you'll be attending summer school ?:biggrin:
What the hell is that? Must be inorganic chemistry...
I like biochemistry and maybe even organic chemistry, but I hate inorganic. -
Its a very complicated cake recipe.:biggrin:Testing
Testing
Testing -
It actually looks more like a solid state circuit status calculation.
The answer is: C.SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
