Chemistry Question
Serendipity
Serendipity Posts: 6,975
edited April 2011 in The Clubhouse
I have some homework due next Tuesday, and not remembering *anything* from high school chemistry, was wondering if any chemists here could explain the following to me:
The Donor concentration in Si crystal is 1017cm-3. Assume complete ionization. Temperature is 300K. At the moment t=0 the 1016cm-3 of excess electrons and holes were generated. Find the position of the electron quasi-Fermi energy with respect to conduction band edge. Find the position of the hole quasi-Fermi energy with respect to valence band edge. Compare to the position of the Fermi energy in equilibrium (before generation of the excess carriers).
I just want to let everyone know that I am NOT looking for just the answer, as it is useless when it comes time for the exam, but would rather know how to solve the problem. I'd GREATLY appreciate it if anyone could give me ANY advice on these, and will say thanks in advance.
- Serendipity
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • Systems
    Systems Posts: 14,873
    edited February 2011
    I like cake.:biggrin:
    Testing
    Testing
    Testing
    nooshinjohn Posts: 25,931
    I find that my two channel rig helps me solve problems just like this one. Have you tried that yet?
  • gdb
    gdb Posts: 6,012
    The crux of the biscuit is the apostrophe :biggrin: Does that help any?
  • steveinaz
    steveinaz Posts: 19,545
    Select "E" One of the above.
  • decal
    decal Posts: 3,205
    The heat of the meat is directly proportional to the angle of the dangle,or something like that !!!!!!
    billbillw Posts: 7,567
    Always amazes me that people come here for academic advice. Kid, read your book, read your notes, and work out the problem. That's the way we all did it back before the internet. BTW, I don't think any High School chemistry would help you in that problem.
  • joeparaski
    joeparaski Posts: 1,865
    I think I got a headache just reading that.
    joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Systems
    billbillw wrote: »
    Word! :biggrin:
    Testing
    Testing
    Testing
  • AudioGenics
    AudioGenics Posts: 2,567
    this will get you going..... good luck on the exam
    fc(k,r) conduction-band state
    fv(k,r) valence-band state
    ni(Tn) thermal equilibrium if Fermi level at Ei & temp Tn
    pi(Tp) thermal equilibrium if Fermi level at Ei & temp Tp
  • Serendipity
    edited April 2011
    Ok, I got this assignment back and apparently answered the question wrong. I guess it's not a simple "substitute and solve" kind of question I was hoping for...
  • gdb
    gdb Posts: 6,012
    edited April 2011
    Does this mean you'll be attending summer school ?:biggrin:
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2011
    What the hell is that? Must be inorganic chemistry...
    I like biochemistry and maybe even organic chemistry, but I hate inorganic.
  • Systems
    edited April 2011
    Its a very complicated cake recipe.:biggrin:
    Testing
    Testing
    Testing
  • cincycat13
    cincycat13 Posts: 888
    edited April 2011
    It actually looks more like a solid state circuit status calculation.
  • ESavinon
    ESavinon Posts: 3,067
    edited April 2011
    The answer is: C.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
