Infinity Prelude Compositions P-FR - 725
aboroth00
Up for sale is a great pair of floorstanding speakers with built in subwoofers. If you know these speakers, then you know they retailed for 4k MSRP. You'd be hard pressed to find better speakers than these for the price. I currently have 2 pairs and a center for if interested in a complete deal, all 5 identical speakers. I am the second owner but the speaker overall is in great shape. I have extra drivers as well.
The vast array of drivers produce tight bass and tight mids. They have a built in 300W 12" subwoofer. They are very efficient at 96db/1v/1watt and are great at home theater even powered by low wattage amps. Due to the thin baffle, the soundstage is HUGE, unparalleled by any speaker I have heard in my room.
Some of the drivers have already been refoamed at great expense. The 12" woofers are in great shape.
Here's some owners reviews: http://www.audioreview.com/mfr/infinity-systems/floorstanding-speakers/systems-p-fr-prelude/PRD_120950_1594crx.aspx
Product Specs: http://www.infinitysystems.com/home/products/product_detail.aspx?prod=IF70018&CheckProduct=Y&Language=ENG&Country=US&Region=USA
Asking 725 for a pair + drivers if interested,
Local pick up in 92841
2Ch Tube Audio Convert
Post edited by aboroth00 on
Damn that is a deal! There was a pair local to me that just sold for $300 and one speaker was missing a few drivers. I've heard these before and thought they were great speakers. GLWTS!--Gary--
They are a great speaker, and it's a shame people don't know more about them. All speakers from Infinity aren't so shabby. They can definitely give the Lsi's a run for their money! However I believe they are virtually unbeatable for the price for a surround sound system. I went searching for years around socal for all these speakers, and even had to disassemble a tower to construct a matching center. For HT, they are giants, especially due to their sensitivity, built in subs, and thin baffles.2Ch Tube Audio Convert
Well, I must say they are some of the best speakers I have ever heard (top 5).
I heard them with some Bryston mono blocks and tube pre.
Unbelievable and it was a very large room to boot!Testing
Testing
Testing -
They are great speakers, and when you account for all the factors, its efficiency most of all it's just a bargain. Especially when you can save a bundle on amps. The high sensitivity allows you to play with lower powered tubes and class A SS amps with great success.
But I haven't had the chance to couple the speakers to Bryston amps and I bet these things would sound great in a much larger room than I have. I would definitely hold onto these if I had extra room for a proper HT setup, but unfortunately now they're just taking up space and they must go. Hopefully I won't regret it down the line.2Ch Tube Audio Convert -
Nobody interested in a great pair of speakers? Make me an offer!2Ch Tube Audio Convert
Ohhh I am interested! I just have a bad case of broke-****-itis.--Gary--
Did i read some were re-foamed? I am shocked they didnt use rubber.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Yeap you did. I guess Infinity chose to use foam with the paper cones. This was perhaps due to he overall design of the driver. But the majority of the woofers have been refoamed and should be good for another 10-15 years. No reason foam is worse off or anything, but IMO it's worth it for these speakers! I was using 5 of these speakers and had to refoam them but I still sucked it up and refoamed them to keep the speakers going.2Ch Tube Audio Convert -
Yes, Infinity used foam surrounds in their BEST speakers.
Less mass?
I have some CS 3007 Crescendos that have foam surrounds.
I had mine refoamed after 10 yrs. of use, they last a very long time.
Back when I bought mine, I found a brand new CS 3007 for $99 (single speaker).
I had to pay $650 for the other one (for a pair) at Ultimate Electronics in Tulsa OK.
They were on sale at the time for $2399/pair (reg $2899/pr.)with FOAM SURROUNDS!
Testing
Testing
Testing -
I'm sure the choice to use foam surrounds was not a cost option. These speakers were their flagship speakers and to cheap out on some rubber seems just madness. Foam was probably a technical decision to bring out the best of the driver. You can tell quality but just handling one of the 5" or 4" drivers. They have literally a 5-7lb magnet on them.2Ch Tube Audio Convert
I have possibly 3 pairs for sale in varying condition: 1 pair for 725, 1 pair for 650 and 1 pair for 575. Come by for an audition and see how wonderful these speakers are!2Ch Tube Audio Convert
They used foam to achieve higher efficiency."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yeap, after some perusing, I came up with the same conclusion. Foam seems to be used to easier attain a certain specification rather than using rubber or even fabric. But unfortunately everything ages and needs to be replaced but foam surrounds are more visible as they age, rubber surrounds tend to stiffen however less noticeably.
"Foam surrounds have just about the lowest distortion component spectra of any surround material.
Fabric has resonant modes ("flapping"), and rubber has hysteresis (non-uniform flexibility and energy storage, depending on deflection amount), among other problems. Both increase distortion beyond what an optimally-designed foam (or foam-impregnated fabric- Tannoy, among others, uses this) surround can do..."
"Any impedance mismatch will result in a reflected wave, whether it's up or down in impedance. You want to match the acoustical impedance of the surround to that of the cone as closely as possible and then use a well damped (like foam) material for the surround. That way you get most of the energy transfered to the surround and then eaten up by the damping."
Learn something new everyday...2Ch Tube Audio Convert -
New foam surrounds generally last longer than vintage foam due to better coatings too. So they may last 30+ years if kept out of direct sunlight, etc.."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the insight Face. That's actually very comforting to know, since most of my current speakers still use foam surrounds. I know they feel different and look different from the older surrounds but I mostly attributed this due to their age, but it seems newer surrounds used today have this light glossy coating to them to protect them.2Ch Tube Audio Convert -
I believe it's UV protection.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Any interest/offers? Great speakers here.2Ch Tube Audio Convert
I've owned a pair of these and they sounded fantastic...even with modest equipment. I'd snatch these in a second if they were local.
bdaley6509 wrote: »I've owned a pair of these and they sounded fantastic...even with modest equipment. I'd snatch these in a second if they were local.
I'd have to agree. The only problem is not too many people know about these speakers.2Ch Tube Audio Convert -
Do you still have a pair of these for sale?
Yeap still available. You can reach me at my email aboroth00@gmail.com2Ch Tube Audio Convert
Are these still available? I live in zip 92780.
Cant tell you how many times these have tempted me. Both these and that custom sub you probably still have for sale.
GLWTS!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks! For their price, their sensitivity, soundstaging, they're a very unique speaker! As you can see from the ad, I once had the complete 5 speaker surround sound and wow... I only have the pair left and the center but the center is unfortunately quite banged up from improper storage.2Ch Tube Audio Convert
