Foam 'bungs' - can they make a difference? I think so
Erik Tracy
So, I've had a **** of a time integrating my sub into my 2-channel setup which uses bookshelves.
Due to room constraints, I have my bookshelf speakers wall mounted with the old BTech mounts. Great for point/angling into the sweet spot, but still - close to the wall, so I get a tad too much bass reinforcement and resulting 'sloppy' bass.
My bookshelves are the B&W CDM 1NTs which are front ported that I picked up used - but the previous owner did not have the original foam 'bungs' (plugs) that fit into the front ports.
I found the USA B&W support center and ordered a set and just recently got them.
They seemingly act as a kind of low cut off device and have allowed me to tighten up the overall bass response with my sub - kinda like an analog equivalent of AVR bass management.
With my integrated amp and directly connected 2-channel sources, I've gotten a slight but noticably better integration of sub & bookshelves, by letting the sub do its job for bass and 'plugging' the bookshelves from trying to reach too deep (and too close to the wall).
Always learning.....
Post edited by Erik Tracy on
Still got the sealed epik? Are you able to take the speakers off the wall and put them on speakers stands? They'll sound much better.
Still got the Epik Valor - still like it.
I wish...but there is 'stuff' under the bookshelves since I have a narrow front wall with the HDTV (wall mounted).
If I had room for stands, I'd probably go towers.
Life is about constraints, tradeoffs, and compromises....
Yes the foam plugs restrict the air flow in the port ,doing so reduces the ports output considerably.Since the ports purpose is to augment the bass below the range that the woofer handles, bass response will be less extended with the plugs.(The speaker will be acting more like a sealed box.)This helps in cases like yours where near wall placement can cause the bass to become too prominate.The resulting higher cut off frequency and shallower roll off slope can sometimes as you found aid in the inegration with a sub.Erik Tracy wrote: »They seemingly act as a kind of low cut off device..
Odd word though...bung.....
I've had the bungs in one of my subs and two of my speakers, and they do work well for restricting and tuning bass.
huhuhuhuhuhuh....you said bung....huhuhuhuhuhuhuh.....
Beavis and Butt-head are coming back....seriously dude..
http://www.comicsalliance.com/2011/02/04/beavis-and-butt-head-return-mtv-this-summer/Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
Covering the ports makes into a sealed box which has a nice 3db per octave rolloff which makes it much easier to mate to a sub. With the port open the response is flat down to some frequency then has no response below that. This is very hard to mate to a sub.
A sealed enclosure will have 12/DB roll off per octave and better transient response(depending on Q). Plus blending to a sub will be easier."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well - whatever the effects - I'm in a 'happier' spot with speaker-to-sub integration.
Seems to have tamed a small room peak/reinforcement I was having as well.
Worth the $ in my book!
Erik Tracy wrote: »Odd word though...bung.....
I've long enjoyed using the term bunghole to describe some folks, in a vulgar slang kind of way.:biggrin:Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
12db, not 3db. My bad.
Well it's not a brickwall.There will still be some output below the ports tuning point but the roll off rate is about twice that of a sealed box at 24db vs 12db.... the response is flat down to some frequency then has no response below that. -
A filter with 24db roll off would pretty much be considered a brick wall filter wouldn't it?Vinyl, the final frontier...
Not at all."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Hmmm, I do see a writeup considering excess of 50db a brick wall. 24 seems pretty extreme to me for audio.Vinyl, the final frontier...
I'll admit that I'm a bit slow...so, if other folks are using these - would like to hear about their experiences.
If others have ported speakers and a sub - you may want to experiment with your own bungs....:biggrin:
With a typical 24dB(4th order) crossover, there is still plenty over overlap between drivers.
Joseph Audio's Infinite Slope crossover is the closest you'll find to a brick wall filter in this type of application. You would need to go active to implement this between a woofer and sub, otherwise the parts size and count would be ridiculous.
That first one is near textbook LR4,I assume it's someones DIY effort?
Some years back I read the patent for Modafferi's Iinfinite slope .Interesting stuff. -
A "bung" is the plug-type thing used to seal up the hole in a wooden barrel...and I didn't even have to look that one up!
You can always stuff the port with Dacron fill material, as per Mr. Von Schweikert...Steve Carlson
Von Schweikert VR-33 speakers
Bel Canto eVo2i integrated amp
Bel Canto PL-2 universal disc player
Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
VH Audio Flavor 4 power cables
Polk Monitor 10B speakers, retired but not forgotten
