carver amp
chemical
anyone familiar with carver av 405 amp??
the seller is asking 200.00 for it.....sounds like a great deal to me.
i have an onkyo 806 receiver...polk m70 fronts.....polk m50 surrounds....polk cs2 center
any help will be greatly appreciated
thanks
thanks
Post edited by chemical on
If I Recall correctly t is a 5 channel amp. if it is in good shape then $200 is pretty good. carver is well regarded around these parts. Is it local? Shipping would not be cheap as these amps are heavy. I would say pick it up if u like it.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
I know and have heard this amp. It is a very good amp, and $200 is a nice price for it.
Left and Right channels are 100 watts
Center is 110 watts
Rears are 50 WattsSunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
I have the AV705x (its bigger brother). I love my amp and got to hear it on some SDA's and MagnePlanar's as well as LSi 15's this weekend.
That is a good price for the amp and that amp will work fine w/ your setup. That amp should be able to drive 4 ohm speakers as well so it will work with just about anything you throw at it (with exceptions of course, the Maggies I listened to this weekend were taxing it a bit).
You should be able to use it on some SDA's, LSi's, or RTi's if you ever go with any of those."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
