APC H15 On All the Time or Triggered?
mufsoman
mufsoman Posts: 636
Just installed my new purchase; an APC H15. Should I leave this unit on at all times, or control it with the 12v trigger to turn on when the AVR is turned on? Am I loosing any protection when the unit is off? The manual isn't very clear on this. Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
  • NotaSuv
    NotaSuv Posts: 3,871
    edited April 2011
    I leave mine on 24/7 unless I am going away for a few days and then I i unplug everything just in case...
  • Conradicles
    Conradicles Posts: 6,344
    edited April 2011
    I leave mine on all the time and unplug on vacations. I like the dimmer function that all lights can be turned off. Great unit.
  • phipiper10
    phipiper10 Posts: 961
    edited April 2011
    Yep, exactly as the guys above said.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2011
    Ditto to the above 3 posts~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • gfong
    gfong Posts: 1,079
    edited April 2011
    Leave it on, page 6 in the manual.
    On/Off switch
    Controls power to all 12 outlets. APC recommends the unit be
    left ‘on’ at all times.
  • Beta
    Beta Posts: 267
    edited April 2011
    I use an H15 in my HT system. It's been on continuously for several years straight and I have never once had any issues. It's been a solid unit for me. Especially given it's relatively low price.
