Monitor 10b XO board
Jack A
To All, Does any one know if the Monitor 10b xo boards are still available from Polk Audio?
I am doing a xo upgrade and I found one of the corner holes is broken.
I would like to replace the board....see attached pic.
Clarajack
Post edited by Jack A on
No they don't.
Keep an eye on E-Bay. Currently there are a couple for the Monitor 5 and 7. The 10's do come on from time to time. Just keep checking back on E-Bay. -
Jack, if you are talking about the hole for the plastic stand off I don't see that as being a problem, unless there is damage underneath that we can't see. I would get the appropriate sized fiber washer to go over the stud and it should hold the board in place. Just my 2?.To All, Does any one know if the Monitor 10b xo boards are still available from Polk Audio?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Hi Ronnie, Good idea about the washer this was done my Polk. I saw this when I opened the xo for the first time.
Did you received my pic of the Vampire binding post installation and fuse removal?
JackClarajack -
Didn't get the photos Jack.Hi Ronnie, Good idea about the washer this was done my Polk. I saw this when I opened the xo for the first time.
Jack- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
Ronnie, I did a upgrade from Vista to Windows 7 and have had nothing but problems.
I'll try again when I find out whats wrong.
JAckClarajack -
Looking at that original pic i can't see why it would cause a problem. It is on the outside edge of the board where there is no wire imprint. Can you disconnect the board so we can see the other side?
moshun111 reported^^
Joe08867, Your right this is the way it came 28 years from Polk. should not be a problem.Clarajack
I had a feeling I was right. It's nice to get confirmation. Have fun with the upgrade!!!!
