Monitor 10b XO board
Jack A
Jack A Posts: 77
edited April 2011 in Vintage Speakers
To All, Does any one know if the Monitor 10b xo boards are still available from Polk Audio?
I am doing a xo upgrade and I found one of the corner holes is broken.
I would like to replace the board....see attached pic.:confused:
Clarajack
Post edited by Jack A on
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited April 2011
    No they don't.
    Keep an eye on E-Bay. Currently there are a couple for the Monitor 5 and 7. The 10's do come on from time to time. Just keep checking back on E-Bay.
  • TennMan
    TennMan Posts: 1,267
    edited April 2011
    Jack A wrote: »
    Jack, if you are talking about the hole for the plastic stand off I don't see that as being a problem, unless there is damage underneath that we can't see. I would get the appropriate sized fiber washer to go over the stud and it should hold the board in place. Just my 2?.
  • Jack A
    Jack A Posts: 77
    edited April 2011
    Hi Ronnie, Good idea about the washer this was done my Polk. I saw this when I opened the xo for the first time.
    Did you received my pic of the Vampire binding post installation and fuse removal?
    Jack
    Clarajack
  • Jack A
    Jack A Posts: 77
    edited April 2011
    Thanks for the tip.
    Clarajack
  • TennMan
    edited April 2011
    Jack A wrote: »
    Jack
    Didn't get the photos Jack.
  • Jack A
    Jack A Posts: 77
    edited April 2011
    Ronnie, I did a upgrade from Vista to Windows 7 and have had nothing but problems.
    I'll try again when I find out whats wrong.
    JAck
    Clarajack
  • Joe08867
    Joe08867 Posts: 3,919
    edited April 2011
    Looking at that original pic i can't see why it would cause a problem. It is on the outside edge of the board where there is no wire imprint. Can you disconnect the board so we can see the other side?
  • Joe08867
    edited April 2011
    moshun111 reported^^
  • Jack A
    Jack A Posts: 77
    edited April 2011
    Joe08867, Your right this is the way it came 28 years from Polk. should not be a problem.
    Clarajack
  • Joe08867
    edited April 2011
    I had a feeling I was right. It's nice to get confirmation. Have fun with the upgrade!!!!
