SDA-1C in my living room...
  • nspindel
    nspindel Posts: 5,343
    edited January 2009
    Looks like Polk got a lot of mileage out of that board! :rolleyes:
    heiney9 Posts: 25,447
    edited January 2009
    Not sure if this helps but 1C's depending on when they were manufactured come with 1 of 2 types of board.
    1) split between 2 x-over boards
    2) a single x-over board.
    IIRC, the later model 1C's come with the single board x-overs.
    Again not sure if this info helps
  • nspindel
    edited January 2009
    My 1C's have the split board:
  • Face
    Face Posts: 14,340
    edited January 2009
    nspindel wrote: »
    For all we know, it may not have been Polk's doing.
    I would crack open both speakers to see if the crossovers are the same in both speakers. Also, get the part numbers off all the woofers. Oh, and it looks like they may be 4 ohms after all.
  • nspindel
    edited January 2009
    Face wrote: »
    Precisely what I was just thinking.
    edited January 2009
    1C's are all 6 ohm nominal as far as I know. That was one of the changes between the 1B and 1C. But anything is possible with Polk as they always likes to use up old stock even in new models ;).
    The 6 ohm is because of the driver compliment. The later SRS2's are also 6 ohms as they use the same drivers as the 1C
    nooshinjohn Posts: 25,932
    edited January 2009
    they share the same x-over design in each speaker, all woofers/sda channels match the replacement guide in the forum and all inspection dates are the same on all drivers. in fact my passive units were born today! HAPPY B_DAY!!! lol.
    the only thing i can say is that with exception to the binding posts, which I modded last nite, these are untouched internally. I am going to recondition their appearance first, then upgrade the x-overs and tweeters. that said, all i can say is WOW. I found a vintage 1990 alpine reference cd used to demo the performance of car audio and i am amazed at how easy it is to hear the breath of a flutist or the pages turn on sheet music when listening in stereo. i even get the effect of surround sound from just two speakers!
    It has been more than 10 years since I had sda's in my home. my last were sda-srs 1.2tl's which the ex got in a divorce, then kindly had taken to the curb when she no longer had room for them.:eek:..:eek:.. it feels good to have decent sound again:D
  • nspindel
    edited January 2009
    Stories like this just tear at my heart...
  • casualinfoguy
    casualinfoguy Posts: 10
    edited March 2011
    Do you know where I can get replacement drivers for the SDA SRS 1.2TL -- everything except the Passive Radiator??
    treitz3 Posts: 20,016
    edited March 2011
    Polk Audio would be my guess. Try giving them a call. Don't e-mail them, call. Here's the number.
    866-764-1801
  • dpowell
    dpowell Posts: 3,081
    edited April 2011
    The XO upgrades are a MUST. RDO tweeters. Also consider spikes or granite slabs (what I did because I had them on hand) to improve bass response. Haven't done the rings yet but they are here waiting for me to have a free day. I run the 1C's off the 4ohm outputs of my amp. Definitely go with a tube amp down the road if you want to bring out the soul in them.
  • thsmith
    thsmith Posts: 6,082
    edited April 2011
    ^^^^ A man that knows what he is talking about. Gets those rings on, as far as must goes put it right behind xo and rdo.
