carver amp
chemical
chemical Posts: 100
edited April 2011 in Electronics
anyone familiar with carver av 405 amp??
the seller is asking 200.00 for it.....sounds like a great deal to me.
i have an onkyo 806 receiver...polk m70 fronts.....polk m50 surrounds....polk cs2 center
any help will be greatly appreciated
thanks
Post edited by chemical on
  • packetjones
    packetjones Posts: 1,059
    edited April 2011
    If I Recall correctly t is a 5 channel amp. if it is in good shape then $200 is pretty good. carver is well regarded around these parts. Is it local? Shipping would not be cheap as these amps are heavy. I would say pick it up if u like it.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • thuffman03
    thuffman03 Posts: 1,325
    edited April 2011
    I know and have heard this amp. It is a very good amp, and $200 is a nice price for it.
    Left and Right channels are 100 watts
    Center is 110 watts
    Rears are 50 Watts
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    EndersShadow Posts: 17,704
    edited April 2011
    I have the AV705x (its bigger brother). I love my amp and got to hear it on some SDA's and MagnePlanar's as well as LSi 15's this weekend.
    That is a good price for the amp and that amp will work fine w/ your setup. That amp should be able to drive 4 ohm speakers as well so it will work with just about anything you throw at it (with exceptions of course, the Maggies I listened to this weekend were taxing it a bit).
    You should be able to use it on some SDA's, LSi's, or RTi's if you ever go with any of those.
