DSWPro500 hummmm.....
Chameleon2
Chameleon2 Posts: 112
Just started yesterday.
Thinking it might be the 60hz problem - just don't know how to solve it.
Any suggestions?
Post edited by Chameleon2 on
  • Conradicles
    Conradicles Posts: 6,036
    edited March 2011
    Maybe start with a cheater plug to see if it is a ground loop hum. Has it been working fine in the past?
  • Chameleon2
    edited March 2011
    Sorry, I guess I could have given a bit more background.
    Have had the s/w for ~2 years; worked great.
    Just watching the TV yesterday (A/V receiver off) and heard the faint sound.
    [Actually haven't used the A/V system in 2 weeks.]
    Switched power cables (had been using one with a 90 degree bend from monoprice) back to Polks's cable; hum still there.
    Even bypassed the power strip completely and plugged directly into 2 different wall outlets; no change.
  • SRTer
    SRTer Posts: 372
    edited March 2011
    Chameleon2 wrote: »
    Any suggestions?
    What's this I hear about a 60hz problem? Please explain or post a like to the thread with the information.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • kevhed72
    kevhed72 Posts: 4,958
    edited March 2011
    Do a search on "Ground Loop" and you will find a ton of info. here.
    The trick is figuring out where the ground loop hum is originating.
    edited March 2011
    k72 has a point. The most common cause of ground loop feedback is your VIDEO cable connections/equipment.
    But, the OP claims that he was fine for 2 years? Hmmmm....have you 'changed' anything in your rig 'recently'--especially any video connections?
    Can't think of anything else. Others will chime in.
    cnh
  • Chameleon2
    edited March 2011
    Changed anything....no, it's been "as-is" for a long time.
    As I posted before, I have not used the system in 2 weeks when I started hearing the noise.
    I'll try changing the cable this evening (fyi, connection is from the A/V sub-out to the s/w LFE).
  • Chameleon2
    edited March 2011
    Well, tried 2 different cables, hum still there.
    :confused:
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2011
    cablebox is usually the culprit.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Chameleon2
    edited March 2011
    Ron Temple wrote: »
    Sorry, I'm not sure what you mean by cablebox.
    Is it the part (component) of the s/w where the cable connects too?
    Replaceable? A plug-in component or soldered?
  • AverySteven
    AverySteven Posts: 1
    edited March 2011
    Yes you are right
    good post
    I concede it is not surprisingly easy for me wholly to construct varied scientific achievements, because especially I can really reveal the juice of the tip and related with it dubieties. It is cultivating for me in-full to locate college research papers secretly, because mostly it is unavoidable pawning of correct outputs. I need I can use this extraordinary facilitation in future.
  • Chameleon2
    edited March 2011
    Chameleon2 wrote: »
    :confused:
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2011
    Ron Temple wrote: »
    Is this typical? Reason I ask is that I just got a new entertainment center and because of its design I had to put the cable box on the shelf above my avr which is much closer than it used to be. Everything else is the same including where everything's plugged in. I have developed a hum in my BIC F12 and was just too tired last nite to troubleshoot the issue. Putting that furniture together is a pain in the ****.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • Chameleon2
    edited March 2011
    Alright, cablebox as in DVR or whatever for the TV. Didn't realize that is what was meant since I have no idea how that could affect this sub and not the others.
    Hum still there and no solutions other than unplugging and not using it.
    tonyb Posts: 32,906
    edited March 2011
    Go buy a $2 cheater plug and put it either on the power cord for the subwoofer,or the AVR.
  • Chameleon2
    edited April 2011
    what's a cheater plug?
    tonyb Posts: 32,906
    edited April 2011
    Converts a 3 prong plug to a 2 prong. Any hardware store, Home depot, Walmart, carries them.
  • Corties55
    Great article. I'm dealing with some of these issues as well..
    0xc0000005
    Viking64 Posts: 6,678
    I have been waiting 9 years to find out what was wrong. Thanks for the bump.
