Sunfire Cinema Grand Sig Edition
bsoko2
I just installed one today (5 channel) and was wondering about the RCA plugins on the back. There are dual RCA jacks on the back labled Voltage Source and Current Source. Which one is best for listening and playing music or movies? OR, what is the difference between the two? This only is for the mains and center.
However, it does sound really good thru my moded 2.3TL's.
Thanx, Bill
Thanx, Bill
My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
Post edited by bsoko2 on
Try both. One is suposed to mimic the tube sound. Make sure you turn off the amp before switching.
Take care Bill
Ben -
I run the Voltage taps to the mids and the current taps to the tweets. This really helped take the brightness out of the SL3000's. If you still have some of them BTW I am in need of a couple...
Here is the manual for the amp, which will explain better.
http://www.sunfire.com/manuals/Cinema%20Grand%20Signature%20Series%20II%205-Channel%20Power%20Amplifier%20Manual.pdfThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
First, congrats on your buy and welcome to the SigCin Club. How far did you jump when you plugged it in? :biggrin:I just installed one today (5 channel) and was wondering about the RCA plugins on the back. There are dual RCA jacks on the back labled Voltage Source and Current Source. Which one is best for listening and playing music or movies? OR, what is the difference between the two? This only is for the mains and center.
Thanx, Bill
Just to settle the terminology, those aren't "RCA pluggins" they're speaker binding posts that accept banana plugs.... which I highly recommend you use. Very tight back there...
Above reply sets you up for a bi-wire rig... definitely worth trying. For even more grins you can tap the surrounds for voltage outputs to your MW's and the L/R current outs for your tweets. The referenced manual details the jumpering to accomplish this.
I bi-amped my SRS's that way... and trust me none of the "that ain't true bi-amping" crowd will bother you when you use a Sunfire SigCin...
More later,
Tour...
Vox Copuli
Prior to the Sunfire I was using Carver M1.5t for my amps on my speakers. Yes, the Sunfire puts out more juice (3 db more) then the Carver. I really like the tube SQ.
Ben, glad to hear from you. How are you doing?
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Watched the P-51 Mustang attack on the tanks in Valkeryie and the airstrip landing of Hitler. Freakin awesome with the Sunfire. Hit 110 db with no sweat and the calirity in the audio is amazing. This is the way to watch movies.My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
Wait until you try it with two channel audio.:biggrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Im very Jealous of you bsoko2, Ive been looking everywhere for that amp!!! Congrats to youTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Got on ebay for 1600 shipped and it is the 405 wpc. Can't say enough about this amp, just awesome!My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
HAHA..That must of been you bidding against meTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Sorry, I meant 1699 with free shipping and it was a "Buy It Now" deal. I did bid on the one you were bidding on and it went close to what I paid anyway and it was the older model at 400 wpc.My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
If you are going to use the current and voltage connections you may want to consider addind an active crossover before the amp. This way you can limit the input closer to the signals that will be used. No since in sending the Low Fq signals to the tweeters. Example If you 'Amp' 80Hz signal and send it to the tweeter the speaker or passive crossover is going to peel this back off. So if you use an active crossover prior to the amp you will be more efficient in that less will be wasted amping up a signal the speaker isnt going to use.
Just my 2 cents. Have fun with it! -
Well... so much for the bi-amp patrol not bothering SigCin owners...
The efficiency gain is slight. While the HF Ch's' amps will step up the voltage, because the x-over capacitor generates a high resistance (100's of ohms) to the LF portions of the signal, the LF power output is vastly reduced.So if you use an active crossover prior to the amp you will be more efficient in that less will be wasted amping up a signal the speaker isnt going to use.
More later on this is a new thread....More later,
Tour...
Vox Copuli
I bought some Monoprice RCA to XLR 6 foot cables and got a "out of phase" message on my reciever while doing a calibration. While the speakers were just sitting with no audio, I got "poping" noises from the mains via the amp. RCA plugin on Pio SC-37 Elite reciever and XLR plugin on the Sunfire Cinema Signature Edition 405. Checked scematic on the Sunfire manual for the XLR and compared to Monoprice XLR and the wiring doesn't match. Went to the Mackie Speakers page and looked at a XLR plugin and it is different than the Sunfire plugin as far as the pin arragnement with hot and cold. What gives??My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
Just wondering why you would even bother buying the rca to xlr converters. Your not going to benefit by having them so I would tell monoprice they don't work and get your money back.If life had more tubes it would be a lot smoother.
chargerman426 wrote: »Just wondering why you would even bother buying the rca to xlr converters. Your not going to benefit by having them so I would tell monoprice they don't work and get your money back.
Going to get my $$$ back. I was wondering why the Sunfire XLR and the Mackie XLR are wired different?My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Voltage Source: Normal voicing of sound.
Current Source: Supposed to be tube sounding voicing
I can tell a bit of a difference on mine. I tend to use Voltage sounce. Base seems to be stronger though highs are a bit more bright.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
You guys are misleading bsoko2. He's talking about the DUAL RCA INPUTS on the Sunfire. They are intended for being able to bi-amp (or MULTI-amp) from a single source by daisy-chainging from one channel to the next. It's fully possible to drive 7 channels/speakers from only one input this way. Pretty cool feature:
The Current/Voltage tap OUTPUTS are separate:
THESE can be used to separate the voicing (Current = tube-like) between upper/lower range of your speakers.
These amps are incredibly versatile.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Sunfire pinouts follow the EIA International Standard for balanced pinouts:
EIA Standard RS-297:
So your Mac must be WRONG!!:biggrin:TNRabbit
Sunfire TG-IV
The sunfire grand signature edition 5 channel 405 wpc manual has the XLR as;
1 is ground
2 is negative
3 is hot
misprint or was Carver ahead of his time????My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Sure we are... :rolleyes: ...that's why he said this...There are dual RCA jacks on the back labled Voltage Source and Current Source.
So get your little pic back out and circle the RCA's labelled "Voltage" or "Current".More later,
Tour...
Vox Copuli
Bi-amp patrol ?? Hmmm....do we get cool jackets or somethin' ? With a nice official looking patch I hope.
lsi 9's -
LOL... well if you like, I can whip something up patch-wise that at least I would think is suitable... :biggrin:More later,
Tour...
Vox Copuli
Thanx, Bill
There are NO RCA jacks labelled Voltage/Current; there are SPEAKER BINDING POSTS labelled Current/Voltage as I showed in the following post.You guys are misleading bsoko2. He's talking about the DUAL RCA INPUTS on the Sunfire. They are intended for being able to bi-amp (or MULTI-amp) from a single source by daisy-chainging from one channel to the next. It's fully possible to drive 7 channels/speakers from only one input this way. Pretty cool feature:
These amps are incredibly versatile.The sunfire grand signature edition 5 channel 405 wpc manual has the XLR as;
1 is ground
2 is negative
3 is hot
misprint or was Carver ahead of his time????Sure we are... :rolleyes: ...that's why he said this...
Here ya go:
As I said above, the SPEAKER outputs are the V/C taps. The RCAs aren't labelled at all. One is for input, one for output---makes no difference which you use. So bsoko2 was confused as far as I know.
Do you have the pic from your manual? Are the same pins labelled with the same numbers? I pulled my pic directly from the Cinema Grand Seven manual...I pulled the pic below from the 400x5 manual on Sunfire's website:
Weird; that model is different for some reason...??? Is the U.S. standard different from International Standard?TNRabbit
Sunfire TG-IV
Quoted from stereo_buff on carveraudio.com:stereo_buff wrote:The same condition exists with the ~two stereo amplifiers; the manual claims that pin 3 is hot, 2 is cold. The de facto standard is, however, the reverse: pin 2 is hot, 3 is cold. I asked Bill at Rita's and he said they changed the units over during production to the latter configuration but failed to revise the documentation. His advice to me was to try it - if it's wrong it will be out of phase.TNRabbit
Sunfire TG-IV
Quote:
With this info from stereo _buff, my carver amp XLR is wired wrong and is wired as per the manual. Monoprice cables were wired proper and that is why I got a "out of phase" warning from my reciever during setup.
Bill, you might consider going inside the amp & swapping the wiring to the two XLR connectors. That would probably be the easiest fix.TNRabbit
Sunfire TG-IV
bill, you might consider going inside the amp & swapping the wiring to the two xlr connectors. That would probably be the easiest fix.
. . . Ok!My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Sigh... Yes, emphasis on was... Sometimes you have to read the whole thread...Here ya go:
Here's Post #4...
And here's Post #24...Just to settle the terminology, those aren't "RCA pluggins" they're speaker binding posts that accept banana plugs.... which I highly recommend you use. Very tight back there...
Above reply sets you up for a bi-wire rig... definitely worth trying. For even more grins you can tap the surrounds for voltage outputs to your MW's and the L/R current outs for your tweets. The referenced manual details the jumpering to accomplish this.There are NO RCA jacks labelled Voltage/Current; there are SPEAKER BINDING POSTS labelled Current/Voltage as I showed in the following post.
:biggrin:Glen Close to TNRabbit (played by Jeff Goldblum) in The Big Chill while impersonating Elmer Fudd... wrote:TNWabbit... If you awe going to sweep in, you awe going to miss a few mewwowdwamas...More later,
Tour...
Vox Copuli
