Faraday Cage
Cpyder
Has anyone considered putting their gear in a Faraday cage?
An effective design should stop outside EM interference from reaching the circuit boards in your equipment. This may correlate with reduced noise.
Or are good pieces of equipment already shielded adequately?
Gear? No...
I did once consider making a pair of grounded, expanded metal grids to put between my SRS's and TV after they gaussed the beejesus out of one CRT, but spitting the SRS's an extra foot apart was all that was necessary.More later,
Tour...
Vox Copuli
No need to get fancy. Technology to the rescue.
http://www.musicdirect.com/product/81909
and
http://www.musicdirect.com/product/74266Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It's on my to-do list, right after "construct tin-foil hat." :biggrin:
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
They make paint also that you just make sure is connected to a ground.
^ Some guitars electronics cavities are painted with that type paint. Some are lined with copper sheeting/foil making a faraday cage as well. :biggrin:--Gary--
They go together... -
Seems a bit excessive considering what amounts of EMI most experience in their homes.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Goodness, I have not heard of Faraday cage in ages! Hum, this reminds me time is catching up with me. :eek:Has anyone considered putting their gear in a Faraday cage[/URL]?DARE TO SOAR:
Hilarious, we usually discuss these on the firearms forum I frequent.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Monster HTPS 7000 MKII
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
Panasonic 60 Plasma -
A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
inspiredsports wrote: »Seems a bit excessive considering what amounts of EMI most experience in their homes.
That may be, but some people spend tens of thousands of dollars on equipment alone. If a good faraday cage, costing only a tiny fraction of that, could block any/all EMI from reaching your equipment, I'd call it a success. However, unless your equipment is hidden, it may look ridiculous to visitors.
carwashguy wrote: »Hilarious, we usually discuss these on the firearms forum I frequent.
Why firearm forums?No need to get fancy. Technology to the rescue.
and
I really don't see how this could reduce EMI, according to the laws of physics. If you are going to try to actively cancel a wave out (EMI being a random wave), you need to measure the wave first and then apply another wave at the same amplitude and frequency 180 degrees out of phase. This is very difficult, especially at high frequencies. See: Wave addition.
That, or you need something to absorb the wave like a good ol' fashion faraday cage.
This product seems to only produce a wave at one frequency @ 7.83 Hz. This would likely have no effect on any EMI. This would be similar to trying to cancel out music playing from your speakers by playing a single tone. Wave addition doesn't work like that.
I'm not saying that product produces no positive results, but it most definitely would not cancel out EMI like a faraday cage. -
1) my hifi already looks pretty ridiculous to most normal visitors - they dont quite get the idea of speakers roughly as large as phone booths (heck, the younger ones don't even know what a phone booth is!).
2a) 7.83 Hz... perilously close to the Brown Note. http://en.wikipedia.org/wiki/Brown_note
2b) yeah, wave addition (superposition) does work like that - that's exactly how noise cancelling headphones work. Arthur C. Clarke wrote a witty short story on the subject in the early 1950s called Silence Please.
2c) If you have EMI with a fundamental frequency of 7.83 Hz it could (in principle) work pretty well... -
. . . that may be, but some people spend tens of thousands of dollars on equipment alone . . .
Yes, they do. 5 digits would almost cover my cables and IC's.
I'm convinced and will start shopping now :rolleyes:VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
What I meant was that you cannot cancel out a wideband wave with a single tone of one frequency. In my example, you could not silence music coming from a speaker with another speaker playing a single tone of any one frequency. In order to cancel music coming from a speaker, you would need to play the exact same song file but with the waveform inverted. Even this would be difficult because you would not get perfect cancellation as the music would be coming from two point sources.
It would be easy to do using software and one speaker. Open up a song in Audacity twice. Invert one and playback both simultaneously. There will be no sound.
Noise cancelling gets very difficult at higher frequencies because you cannot know ahead of time what noise you have to cancel (unlike my example in the previous paragraph). You must measure it actively, and then create an inverted wave to cancel out the noise.mhardy6647 wrote: »2c) If you have EMI with a fundamental frequency of 7.83 Hz it could (in principle) work pretty well...
Even if the interference was at 7.83 Hz, this would only work if you measured the interference and aligned the produced tone 180 degrees out of phase with the actual interference. Otherwise, instead of a wave addition that results in noise cancelling, you could just as easily amplify the interference.
But common sources of EMI come from the radio bandwidth (KHz and MHz range), Wi-Fi (GHz) and cell phones, etc. These frequencies are well above the 7.83 Hz tone produced by that device. -
exactly so.What I meant was that you cannot cancel out a wideband wave with a single tone of one frequency. In my example, you could not silence music coming from a speaker with another speaker playing a single tone of any one frequency. In order to cancel music coming from a speaker, you would need to play the exact same song file but with the waveform inverted. Even this would be difficult because you would not get perfect cancellation as the music would be coming from two point sources.
I think you might be surprised by the spectral distribution of electromagnetic noise.Even if the interference was at 7.83 Hz, this would only work if you measured the interference and aligned the produced tone 180 degrees out of phase with the actual interference. Otherwise, instead of a wave addition that results in noise cancelling, you could just as easily amplify the interference.
The guns guys use them as protection for their electronics from the EMP that will accompany the Nuclear Holocaust that is bound to happen any day now.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
carwashguy wrote: »The guns guys use them as protection for their electronics from the EMP that will accompany the Nuclear Holocaust that is bound to happen any day now.
Heh, vacuum tube electronics will laugh at the EMF pulse when the Big One comes! That's why the Soviets never stopped using vacuum tubes in military electronics... it wasn't backwardness, it was insight :-)
I never stopped using them, either. Well, OK, I stopped for a while, but I regained my senses. Fortunately there are still new production tubes available, largely thanks to the Russians and the Chinese :-)
Yeah, the CDP will go Tango Uniform when the nukes fly, but I'll cue up We'll Meet Again on the record player a la Dr. Strangelove and settle back in a comfy chair to meet the false dawn.
Mmmmm-kay...carwashguy wrote: »The guns guys use them as protection for their electronics from the EMP that will accompany the Nuclear Holocaust that is bound to happen any day now.
Sounds like a better plan... only lacks an 18-yo single malt... and maybe a generator...mhardy6647 wrote: »Heh, vacuum tube electronics will laugh at the EMF pulse when the Big One comes!
... I'll cue up We'll Meet Again on the record player a la Dr. Strangelove and settle back in a comfy chair to meet the false dawn.More later,
Tour...
Vox Copuli
Love the false dawn bit.Living Room
LSi 15
LSi7
LSiC
LSiFX
2 EPIK Empire
2 W4S Sx-1000
Parasound 5250
Onkyo PR-SC5508
Oppo BDP-95
Pro-Ject RM 1.3
LG 55 LED
Bedroom
RTi A7
CSi A6
FXi A6
2 PSW 125
Onkyo TX-NR1008
carwashguy wrote: »Love the false dawn bit.
Stole that (slightly modified) from Arthur C. Clarke's Childhood's EndAnd the island rose to meet the dawn
