Sub Issue
antsanta
antsanta Posts: 2
edited April 2011 in Troubleshooting
I purchased my psw10 a month or two ago and everything was going fine, but recently I've been having some problems. The bass response is nowhere near where it used to be, especially standing in front of the sub. If I stand on either side of it, it sounds fine but not quite like it used to, but when I'm in front of it, it sounds all fluttery like it was blown. I have pushed it before but never max volume and the problem occurred well after I had it cranked. Anyone have any ideas on what the problem could be?
Post edited by antsanta on
  • slk55amg
    slk55amg Posts: 305
    edited March 2011
    I have one, its not a great sub, I currently use it in my bedroom, its ok for that, I replaced it with a Micropro 4000, now that,s a real sub.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
  • antsanta
    antsanta Posts: 2
    edited March 2011
    I'm not exactly on that budget right now haha, can you recommend a good sub for around 300?
  • codyc1ark
    codyc1ark Posts: 2,539
    edited March 2011
    I myself have a PSW10, it sits in storage, I've been meaning to put it up on CL with some other stuff. What are your listioning habbits? If its strictly movies, you may want to look at a BIC sub, they seem to get good reviews and it fits great into your budget, or a HSU STF-1 can had for around ~300.00 with shipping. Good luck, I just did a major jump from my PSW10 and I couldn't be happier, really brings a new depth for movies, the fiancee even approves after watching a few!
  • ROHfan
    ROHfan Posts: 1,014
    edited April 2011
    antsanta wrote: »
    BIC F12. I own one and love it. On Amazon RIGHT NOW for $183 with free shipping. Run, don't walk!
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
