TL 350 questions
Hi,
Im interested into TL 350 set, but I dont know how maximally strong can my amplifier be regarding speaker watts per channel.
The speaker specs say that it should be between 10-125Watt.
If you have to choose between 105 watt/channel amplifier or 125W amplifier/channel with discrete amp configuration.
Second question is to some polk subwoofer recommendation to fit with TL350. In general I dont like bass overkill at all. My living room is 7x5m. Passive subs are preffered.
Peter
Peter
anyone pls?
The speaker is indicating how much power you should send to the speaker. That does not indicate how much power the amp should have. You can have a 1000W amp. Just don't turn it up all the way.
You will likely not require that large of a sub to match the 350 since they are satellites. I have hear anything below PSWi225 is not recommended.Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12 -
I plan to grab the RX-V571 or RX-V671
http://www.heimkino-vision.de/newsarchiv/yamaha-av-receiver-2011/
The 671 model will have dicrete amplifiers for each output and will push 125Watt. So you think attaching TL350 to such receiver would be ok?
