Power Cable
acmf74
acmf74 Posts: 937
edited March 2011 in Electronics
If I had 1 power cable where should I place it to get the most benefit?
Power Conditioner
CDP
AVR
Thanks,
Post edited by acmf74 on
  • jhw59
    jhw59 Posts: 348
    edited March 2011
    probably your amp source I would think
    tonyb Posts: 33,072
    edited March 2011
    Avr.....
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2011
    Try it in each location, or buy 3.
    treitz3 Posts: 19,977
    edited March 2011
    Seeing as how you have the JD100, I would try it there first as they respond well to a PC upgrade. That said, every rig is different and your results may vary. I have found that the most significant difference can be had by upgrading all of the PC's.
    I wouldn't rule out trying it on the sub as well.
  • fishbones
    fishbones Posts: 947
    edited March 2011
    While this might not be the answer you were hoping for. Like some already said, you're going to have to try in each location to see what works best. Different components take to PC upgrades differently, and how your components are working together as a synergistic unit also can vary the results (a PC is part of the chain). Try it in each.
  • acmf74
    acmf74 Posts: 937
    edited March 2011
    My whole system is plugged into the APC. I'm going to start out with my CDP and if I like what I hear I will do the whole system with them.
    Thanks..
    edited March 2011
    Can you test each component without plugging that component into the APC first? I can't say with 100% certainty but you may be hampering the performance by utilizing the APC. Like I said, each system is different.
  • acmf74
    acmf74 Posts: 937
    edited March 2011
    treitz3 wrote: »
    Yes I can. I even have a dedicated line from my fuse box to a hospital grade outlet for my system. :smile:
  • acmf74
    acmf74 Posts: 937
    edited March 2011
    Which cord would be better suited for my CDP?
    The Magic or Digital Reference?
    edited March 2011
    I have ran with the digital reference before and they both paired well. I haven't heard or used the magic, so I can not comment.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited March 2011
    Although I've never tried a Signal cable power cord, I have tried the Pangea AC-9 and that it sounded well no matter what I plugged it into.
  • Conradicles
    Conradicles Posts: 6,339
    edited March 2011
    The AC-9 is a real audio deal. Best power cable I have ever tried, although it is huge and you need some room to work with it and route it properly.
  • Ern Dog
    edited March 2011
    I talked to Guy Placette (owner of Placette Audio) yesterday on the phone and asked him which power cable was the most neutral and transparent. He said don't waste your money there.
    Interesting response and not what I would have expected. To each his own. My experience tells me something different.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2011
    As said above, every system is different so experimentation is needed. I've ended up with upgraded cords on everything, even to the point of installing IEC females to accommodate upgraded power cords on very old vintage gear.
    I have both of those cords and would personally rate the Magic as working well in any position, and the Digital Reference as best for the AVR.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
