7.1 Surround with LSi?
dnoyeB
dnoyeB Posts: 114
edited March 2011 in Speakers
Does it make sense to have a full 7.1 surround system using the LSi series?
The LSi surround speakers are dipoles. Would you use side and rear dipoles? If not, which other speaker should I consider for a rear surround? An LSi7?
Music
LR: Polk Monitor 70 (willing to sell if interested)
C: Cerwin Vega E-75C
Sub: HSU VTF-2 MK3
AVR: Sony STR-DE835
AMP:
HT
5.1: Paradigm CT110
AVR: Integra DTR-4.6
WTB: RTiA9 or RTi12
Post edited by dnoyeB on
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2011
    Depends. I have a 5.1 with 4 LSi15s. I used to have LSi7 for the surrounds, but upgrading to the Lsi15s made a big difference. Don't believe it when people say the surrounds, and/or rears, are not important.
    Also, if you use your HT for multi-channel SACD it helps to have good speakers all around.
  • janmike
    janmike Posts: 6,146
    edited March 2011
    I also have 5.1 using the LSi speakers for my HT(LSi9, LSiFX, LSiC). Tried the 7.1 and there was not noticeable difference for me.
    Michael ;)
    NORTH of 60°
    tonyb Posts: 33,067
    edited March 2011
    Keep in mind the lsi series are all 4 ohm speakers. The 7's being the easiest of the bunch to drive. Just thought I'd throw that out there.
  • janmike
    edited March 2011
    Good point Tony. My Proceed AMP5 has no problem driving them.
    Michael ;)
    NORTH of 60°
  • bdtae5656
    bdtae5656 Posts: 235
    edited March 2011
    Fox... Why not the 9's as rears, are the 15's that good as surrounds ? Thanx
    TV:Sony Bravia XBR4 52'
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Amp:Sunfire TGA-7400
    Blueray: Opp 93
    A/V Component: Panamax M5100-PM
    Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
  • BlueFox
    edited March 2011
    bdtae5656 wrote: »
    The 15s have a built-in speaker stand that is very stable. Also, after I hooked up the 15s, I was surprised at how much more bass I was hearing/feeling than before. I usually keep my sub turned off unless it is a Friday night action movie.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2011
    Keep your back surrounds close together ans set them to bi pole if that is an option.
    RT1
  • bdtae5656
    edited March 2011
    I like the fact that the 15's have a built in speaker stand!!! But really which are better the 15's or 9's for HT surrounds ?
    Mains: Lsi m 705
    C:Lsi m 706
    Rears: Lsi m 703
    Sub: Epik Empire
    Pre:Marantz AV 7005
    Blueray: Opp 93
  • pearsall001
    pearsall001 Posts: 5,241
    edited March 2011
    Full LSi 5.2 system here...LSi 15's, LSiC, LSiFX surrounds powered by a Rotel RMB 1095 multi channel amp. No complaints here! Gorgeous sound for both HT & 2 channel.
    tonyb Posts: 33,067
    edited March 2011
    bdtae5656 wrote: »
    Their is no clear cut answer. Rooms vary, placement issues,size. If your a bass head and you want more bass in the rear, the 15's is your huckleberry. Then again,if you already have a kick **** sub in the mix, you won't notice any loss of bass with the 9's.
