RTI8's on Hardwood Floors
gelinas
gelinas Posts: 226
edited March 2011 in Speakers
Hi All,
I've had my RTI8's for a few years now and have always had them in my carpeted family room. I am possibly moving in the near future and am concerned about my speaker's spike feet on the nice hardwood floors in the new place. I've been fairly unsuccessful in my search for a solution.
I don't really want to put them on a ceramic tile or something of that nature. Does anyone know of replacement feet that are perhaps rubber or something less abrasive to a wood floor?
Thanks in advance.
Post edited by gelinas on
  • Zeros
    Zeros Posts: 940
    edited March 2011
    How about these to go under the spikes?
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270648933971#vi-content
    Make sure you get the foam stickies for the bottom of the discs too. I think he wants 25 cents each for the foam.
    They might be too small, so you might want to go with the bigger gold ones he talks about.
    Here's another nice looking set for $28 shipped:
    http://cgi.ebay.com/Floor-Discs-Disc-Audio-Cones-Speaker-Spikes-Stands-/250606352426?pt=Speakers_Subwoofers&hash=item3a594d782a
  • gelinas
    gelinas Posts: 226
    edited March 2011
    Zeros wrote: »
    Thank you for the great suggestion. Would you happen to use these yourself? Looks like the seller you linked also has a larger size and I'm wondering how they would look with the somewhat fat rti8 spike.
  • Zeros
    Zeros Posts: 940
    edited March 2011
    Nope, I've never used them. I do have RTi8's as well and know how big the spikes are though.
    Maybe the second set I added would work better?
    You could also completely remove the spikes and feet and put the speakers right on the floor, but that obviously defeats the purpose of the spikes. The floors would be OK though.
  • stangjason
    stangjason Posts: 341
    edited March 2011
    Oh how I hate hard wood floors as they play such tricks with the sound.
    Just a thought but I think I would try some of those things that my parents put on the feet of chairs and couches to protect their hardwood floor. Sorry I don't know what they are called though. If not I would consider getting some scrap carpet possibly free or real cheap from a furniture store and cut out the size I needed. My wife is a kindergarden teacher and she has gotten scrap carpet like this.
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
  • gelinas
    gelinas Posts: 226
    edited March 2011
    stangjason wrote: »
    Thanks for the suggestion, but this will be in a family room and will have to pass the WAF so we'll need something with a more refined look than carpet scraps.
  • MLZ
    MLZ Posts: 214
    edited March 2011
    I use coins under the spikes on my RTi8's, they work well and cost pennies ;-)
  • WESTORTHE3RD
    WESTORTHE3RD Posts: 8
    edited March 2011
    gelinas wrote: »
    Hi All,
    Thanks in advance.
    I have rti10's on lyno and was thinking the spikes might punch thru so I went with a hockey puck at each corner,center drilled on a lathe fit the tip of the existing feet and varied the drill depth of the front and back pucks to give about a 3 deg. up projection from horiziontal.If you are a hockey nut, the puck idea may blend in well with your decor. If not you can bevel the top edge and tell the wife it is a custom fabricated floor protector you commisioned the building of just for her:biggrin: Astetics aside this idea works well, and dammage to touchy floor surfaces is a non event.
  • Gadabout
    Gadabout Posts: 1,072
    edited March 2011
    My floors are carpeted, but there are various floor protector stuff at Home Depot or Lowe's.
    Guess it depends on how fancy you want to be.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited March 2011
    Mine are on laminate, and they really don't move around. The "spikes" are really just plastic and are rounded, too. I've been thinking about replacing the stock spikes with metal spikes and using those little disks they have with a dimple in the center. I'd also like to replace the plastic outriggers... a project for another day, though...
  • PSOVLSK
    PSOVLSK Posts: 5,382
    edited March 2011
    I use something similar to the product Zeros linked. This isn't exactly what I have, but close.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-670
  • blehmbo
    blehmbo Posts: 179
    edited March 2011
    Are there any benefits to using spikes on hardwood or tile floors? If there is wouldn't putting a foam pad underneath the floor protector defeat the purpose?
