Bridge Rectifier Q
disneyjoe7
If I would rectify 120vac to get 150-170vdc, could I do another rectifier to get 300 to 340vdc under load?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
What your looking for is a voltage multiplier circuit.http://en.wikipedia.org/wiki/Voltage_multiplier
Not enough current, may need 300+ watts.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
Why isn't enough current? You would only need about an amp for 300W+ at 300V.
You can use the simple, cheap and effective DC step up from Fred link or you can use DC to DC Converter. The caps at high voltage may be a bit costly if you want to have high current supply. Or you can use a small step up AC transformer and then rectify to DC. It's probably cheaper and easier with the AC transformer.
http://en.wikipedia.org/wiki/DC_to_DC_converterTrying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Don't rectify 120vac without a transformer.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben said it right. And I'll add to what he said. Don't do it without a proper rating fuse too.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
This for a HHO Hydrogen idea I have to run my 4Runner on. I was thinking of using a 12vdc inverter to 120vac then rectified to 170vdc. I need to run some test first, but may use a 12vdc inverter to 240vac to rectify to 340vdc or so.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Then maybe you could find a suitable step up transformer to follow the invertor.
disneyjoe7 wrote: »This for a HHO Hydrogen idea I have to run my 4Runner on. I was thinking of using a 12vdc inverter to 120vac then rectified to 170vdc. I need to run some test first, but may use a 12vdc inverter to 240vac to rectify to 340vdc or so.
Good luck with that. It hasn't been successful done yet as far as I know as the electrolysis is far too slow. -
Well I like to think I tried something, other then sit back and done nothing at all.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
