Bridge Rectifier Q
disneyjoe7
disneyjoe7 Posts: 11,435
edited March 2011 in DIY, Mods & Tweaks
If I would rectify 120vac to get 150-170vdc, could I do another rectifier to get 300 to 340vdc under load?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    What your looking for is a voltage multiplier circuit.http://en.wikipedia.org/wiki/Voltage_multiplier
  • disneyjoe7
    edited March 2011
    Not enough current, may need 300+ watts.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • megasat16
    megasat16 Posts: 3,521
    edited March 2011
    Why isn't enough current? You would only need about an amp for 300W+ at 300V.
    You can use the simple, cheap and effective DC step up from Fred link or you can use DC to DC Converter. The caps at high voltage may be a bit costly if you want to have high current supply. Or you can use a small step up AC transformer and then rectify to DC. It's probably cheaper and easier with the AC transformer.
    http://en.wikipedia.org/wiki/DC_to_DC_converter
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • ben62670
    ben62670 Posts: 15,969
    edited March 2011
    Don't rectify 120vac without a transformer.
    Ben
  • megasat16
    edited March 2011
    Ben said it right. And I'll add to what he said. Don't do it without a proper rating fuse too.
  • disneyjoe7
    edited March 2011
    This for a HHO Hydrogen idea I have to run my 4Runner on. I was thinking of using a 12vdc inverter to 120vac then rectified to 170vdc. I need to run some test first, but may use a 12vdc inverter to 240vac to rectify to 340vdc or so.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    Then maybe you could find a suitable step up transformer to follow the invertor.
  • zingo
    zingo Posts: 11,258
    edited March 2011
    disneyjoe7 wrote: »
    Good luck with that. It hasn't been successful done yet as far as I know as the electrolysis is far too slow.
  • disneyjoe7
    edited March 2011
    Well I like to think I tried something, other then sit back and done nothing at all.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
